Old 01-09-2005, 02:48 AM   #1
Default motor modding
Hi! im totaly new, I did have a tamiya car (one of the ones that runs on a track) ahwile ago. Im about to enter a Uk based competition with my school that involes constructing a RC car, I remember a guy tuning his electric motor by adding extra copper wire to the 3 electro magnet terminals, adding more powerful case magnets and adding brass connectors. It was quite awhile ago so its all a bit hazy, are there any guides around? (you are allowed to modifiy the engine as long as it remains identifiable)
thanks v much Sonic ^_^
(I did post this in the rookie forum but no replies :-()
sonicfish is offline   Reply With Quote
Old 01-09-2005, 08:44 AM   #2
this is a good starting point...
http://www.motortuningsecrets.com/tunestockmotor.html
MManson is offline   Reply With Quote
Old 01-09-2005, 09:47 AM   #3
thanks, still wondering about modding the actual motor?
Old 01-09-2005, 09:59 AM   #4
schmelme's Avatar
By adding wire to the motor you will make it slower. You could take an arm and strip it down bare and hand wind one then silver solder the tabs back on then try to balance it and it will still blow up after 1 min of running. The magnets in the motor cases are epoxied in so removing them is pointless you can zap them with a magnet zapper to make them stronger but only slightly. As for modding the actual physical characteristics of the motor people usually dont do this mainly just tuning and tweaking. You want a faster mod motor buy a better bigger motor.
schmelme is offline   Reply With Quote
Old 01-09-2005, 11:05 AM   #5
Slower?! Surely the extra wire would result in a stronger electro magnetic field?
Old 01-09-2005, 11:56 AM   #6
Jack Smash's Avatar
Trader Rating: 29 (100%+)
No, it works the other way. The less winds per pole and larger diameter wire produce more power.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-09-2005, 12:14 PM   #7
ahhhh i see! So if i removed the wire and re wraped with thicker wire, the motor would be more powerfull?
Old 01-09-2005, 12:53 PM   #8
EddieO's Avatar
R/C Tech Charter Subscriber
If it had less or equal turns it would.....but then you have to get it balanced, which can't be done with a prop balancer ( I don't care what anyone wants to argue, it doesn't work correctly)...it takes an expensive specialize piece of equipment.....
In theory, more wire would provide more torque....so I guess it depends on what you define stronger as....
And zapping magnets can have a huge effect if the magnets were overheated and started to demagnetize.....zapping new magnets will usually only make a slight difference.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
bl motor tuning party_wagon Electric On-Road 2 01-30-2008 10:42 AM
Peak Motor Tuning System/MM motor mate dal bains R/C Items: For Sale/Trade 4 11-27-2007 11:21 PM
RC Motor Black Book- motor tuning edwintklee Electric On-Road 5 10-09-2006 01:38 PM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
