Old 04-20-2012, 07:22 AM   #31
daleburr's Avatar
Little bit of good news; the belts are actually so tight that the easiest solution is just to add 1 tooth to the front and rear belts. The diff cams should have enough adjustment to allow the v1 chassis to run with the longer belts. It will probably need the rear belt on the tightest setting and the front on the loosest, so for the CF chassis I'll move the rear layshaft forwards slightly to even things out and leave a decent range of adjustment for each belt.
New longer belts are on order, so when these arrive (probably in a day or two given how quick they were last time) I'll get them on, then drill the layshafts which is the last difficult job remaining (although I do have a few tips on using a jig to make it easier).
Dale
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-20-2012, 07:32 AM   #32
alcyon's Avatar
i am more excited to see your design coming to life, and the other guy with the TC-9, than any other new car on the market today ! i think the science behind this project is RIGHT !
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 04-20-2012, 07:38 AM   #33
Trader Rating: 10 (92%+)
although I do appreciate people 'making' their own cars, the central layout design has been around for a while, E4, jrxs, and tamiyas ta06, they still have not provided any performance/handling advantage over the tradition touring car layout.
captain stacker is offline   Reply With Quote
Old 04-20-2012, 07:48 AM   #34
sagejyoung's Avatar
fantastic design! well done. looking forward to seeing the final product.
sagejyoung is offline   Reply With Quote
Old 04-20-2012, 07:57 AM   #35
Awesome man! I cant wait to hear how it drives.
Pro4
Twism86 is offline   Reply With Quote
Old 04-20-2012, 09:01 AM   #36
daleburr's Avatar
Thats because those cars are all flawed. To centralise the weight side-to-side, they have spread it out front-to-back, which is actually worse. So you're right, in that the previous 'centralised' attempts are not an improvement over the more popular touring cars.
But with a shorty lipo things become more interesting, because you can centralise the weight in all directions
Team Xray
Old 04-20-2012, 05:53 PM   #37
Really Interesting!
MDRTales is offline   Reply With Quote
Old 04-20-2012, 09:11 PM   #38
alcyon's Avatar
you are wrong there. i guess you are not observant enough why those cars did not provide an advantage. i will list the reasons for you
JRXS - in order to get the belts on the extreme sides of the chassis to place the motor and the battery in the middle, the diff had to be very long, causing the bulkheads to be spaced far apart. becuase of that the arms and camber links had to be VERY short, compromising the suspension.
The E4.. the motor is in the middle, but the battery isnt, its partially offsetted if you look carefully. and becuase the battery had to be top loaded, everytime the upper deck had to be unscrewed when you need to swap the battery, causing your tweak settings to mess up. Also if you notice, the upper camber links arent exactly very long.
The TA06. Motor in the middle, and battery in the middle, but the car requires a LOT of hop ups to make it work and the rear weight bias is still too much, becuase the motor is far rearwards. the suspension arms are good, but the front IFS shock layout isnt as good as a standup shock tower type.
Dale's design addresses all these problems as i can see. He uses TC6 suspension which are as modern as can be, he move the motor more forward, to make the F-R balance 50-50.
Old 04-29-2012, 11:14 AM   #39
daleburr's Avatar
Small update. The new longer belts now fitted; the rear belt is a little loose, and the front/middle a little tight (even with the diff cams adjusted as much as possible), so I'll move the main layshaft forwards a touch for the final version and it should be spot on.
I've also managed to cross-drill the layshafts, so the pulleys are now properly attached (no more blu tack!). This could have been a real sticking point as drilling through round hardened-steel bar is far from easy (I just have a drill press, nothing fancy), but managed to make up a jig so I can now drill it accurately each time.
Next stage; top deck and lipo holders.
New car project TC6-C-20120429_180011a.jpg   New car project TC6-C-20120429_175845.jpg
Team Xray
Old 04-29-2012, 11:28 AM   #40
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Battery in the E4 actually drops out the bottom on its own sled. don't have to touch the top deck. no comment on the camber length but they look about as long as anyone's with narrow bulkheads and long arms.
unfortunately, the e4, like the ta06 requires a lot of aftermarket to survive but its a nice car. handles well, easy to drive.
this is looking pretty good. did you make all your own bulkheads or use oem parts from something else?
I might do something similar to my tc5 just cause, but i have so many spare parts and bulkheads for my e4 that i wont really have to make anything.
valk is offline   Reply With Quote
Old 04-29-2012, 12:37 PM   #41
Suspended
You are the man.
How smooth is the drivetrain compere to 2 belt car ??
Jerzi
jerzi is offline   Reply With Quote
Old 04-29-2012, 02:21 PM   #42
daleburr's Avatar
The silver bulkheads and motor mount are XRay parts, with some modifications. Much cheaper and easier than making them from scratch. The rest is standard TC6.
Originally Posted by jerzi View Post
You are the man.
Jerzi
At the moment its a bit tight, partly because the front belts are too tight, but also because the belts are a bit stiffer than the ones normally used on TCs. So once the tension is sorted out and the belts have had a chance to bed in it should be pretty decent. It's never going to feel as free as a 2-belt car, but I doubt it will be noticable on track.
Team Xray
Old 04-29-2012, 02:46 PM   #43
Great thread- subscribed.
Almost makes up for the "which car should I buy" threads that litter the forum.
Losi Mini Desert Truck- big 370 motor/lipo
BL Micro Rally- 3s lipo. Too fast for its own good.
OnlyVees is offline   Reply With Quote
Old 05-01-2012, 09:57 AM   #44
Chrissy C's Avatar
Nice work Dale, been following the thread, but wanted to comment so I see the updates
What belt length/teeth count are you uisng or need? I have accumilated a large database of belt lengths etc. I used the stiffer ones to get the right count and then manged to find some RC ones - it really freed up the transmission nicely. I'm sure you've done the research, but the offer's there if you need it.
I've been getting a few bits made up from Fibre-Lyte lately, their turnaround and quailty is great, it really brings the project to life to get some sexy CF on the car
Look foward to the next update.
Best
Chris
Chrissy C is offline   Reply With Quote
Old 05-01-2012, 12:45 PM   #45
KDagh1's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Cool! Looks like a solid chassis with improved handling. Eager to hear how it works out.
KDagh1 is offline   Reply With Quote
Project: Team Associated TC9 eds24 Electric On-Road 140 11-29-2012 09:45 AM
