Old 03-10-2012, 03:53 AM   #16
daleburr's Avatar
Originally Posted by mooby64 View Post
With the placement of the motor and rear pulley assembly, it appears that you will be very limited in the amount of space for motor adjustment/gearing selection.
Well spotted. The black pulleys are much bigger than they need to be, I'm going to reduce the diameter of the fences by about 2mm which should give enough room. I only race on large Tarmac tracks so won't need to gear down much more than that.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is online now   Reply With Quote
Old 03-10-2012, 03:56 AM   #17
daleburr's Avatar
Originally Posted by M.Abramowicz View Post
Good luck!
this fiber glass was cut on cnc?
ps: It's pushing me to made home cnc
I wish. It was cut using the good old Dremel! It was drilled using a pillar drill though so the holes are accurate enough for a prototype.
The final carbon version will be CNC cut by fibrelyte
Team Xray
Old 03-10-2012, 08:55 AM   #18
Conrad's Avatar
Jigsaw's a re good for cutting large pieces of fibreglass but for the smaller stuff I use a tile saw, very good for cutting c/f as well, nice and quite and with minimal wear on the blade.
Nice to see the car fleshed out, I know the original concept was to have the electronics as tightly compacted as possible but now you can see it in the flesh you realize how tight it really is :O
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 03-21-2012, 10:08 AM   #19
wtcc's Avatar
So how far have you come? Any news?
wtcc is offline   Reply With Quote
Old 03-21-2012, 11:27 AM   #20
daleburr's Avatar
Just purchased another TC6 off eBay to use as a donor car for suspension/diffs/bulkheads etc. I was originally going to strip my existing one down but with the race season fast approaching that seemed like a bad idea! Used TC6 prices are now very low with the 6.1 out, so this looked like a more sensible option.
I'll post some more pictures (hopefully next week) when it's all assembled. That will allow me to check the front/rear WD, and if it's correct I'll order the belts and make up a top-deck.
So still lots to do... I feel another day of holiday coming up spent in the garage
Team Xray
Old 04-13-2012, 03:07 AM   #21
daleburr's Avatar
Finally had a couple of spare evenings to get the car built up with the TC6 donor parts and spare radio gear out of my buggy. The HW ESC is huge but just about fits in (the GM that I normally run is currently in my main TC6). Please ignore the wiring, that still needs tidying.
The weight distribution is exactly as calculated; 50/50 front-to-rear and left-to-right. I'm very pleased with that, and with how tightly packed everything looks. The rear-end looks anorexic compared to a normal TC
The final jobs are:
1. Order the belts. I have a supplier that will cut to width so I'll get these ordered today.
2. Make a top-deck (easy)
3. Make some lipo holders (easy)
4. Fix the pulleys to the layshafts (hard; I have to cross-drill the layshafts as the pin holes have the wrong spacing. Worst-case scenario I'll bond the plastic pulleys to the layshafts as both are cheap and can be replaced as a unit if needed)
New car project TC6-C-20120412_223918.jpg   New car project TC6-C-20120412_224030.jpg   New car project TC6-C-20120412_224039.jpg   New car project TC6-C-20120412_224052.jpg   New car project TC6-C-20120412_224110.jpg
Team Xray
Old 04-13-2012, 03:47 AM   #22
wtcc's Avatar
Wow! Nice work!
Do you raise the topdeck or make it asymetrical to avoid the motor?
Old 04-13-2012, 10:09 AM   #23
daleburr's Avatar
Wow! Nice work!
The top-deck will go around the motor, but will still be symettrical. Drawing attached. I never raise the CoG of anything if I can avoid it.
Team Xray
Old 04-13-2012, 01:15 PM   #24
heretic's Avatar
Really like how this is coming together ! I will follow the rest of the build with interest.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 04-13-2012, 01:52 PM   #25
Trader Rating: 24 (100%+)
Looks absolutely amazing. I under stand the advantages of having 50/50 wd and a low cg but it looks like the spur gear is lower then the chassis. did you cut the chassis there to get it to fit in there?
Flipside6900 is offline   Reply With Quote
Old 04-14-2012, 01:48 AM   #26
daleburr's Avatar
Thanks for all the positive comments guys, really appreciate it
There is a small groove under the spur, it's not cut all the way through as the spur is at the edge of the chassis and a cut would look crap there.
Team Xray
Old 04-14-2012, 11:05 AM   #27
gom
This is really nice work. keep it up!
gom is offline   Reply With Quote
Old 04-18-2012, 12:09 AM   #28
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Looking good, can't wait to see it completed.
Dan is offline   Reply With Quote
Old 04-18-2012, 02:36 AM   #29
daleburr's Avatar
The belts have now arrived and even on their loosest settings they are too tight. I used a calculator from the belt manufacturer for calculating the pulley spacings, then took a bit off as I figured the suggested figures would be on the tight side. Guess I didn't take enough off!
So I need to make a second prototype chassis with the diffs moved about 0.5mm towards the centre of the chassis, to slacken the belts off. Shouldn't take too long; it took about half a day to make the first chassis, and the second one should be quicker.
So hopefully have some pictures soon of the second chassis, with the belts all fitted and ready to go.
Team Xray
Old 04-18-2012, 02:39 AM   #30
mingnon's Avatar
cant wait to see 2nd chassis, am following with interest, thanks for all your hard work
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Project: Team Associated TC9 eds24 Electric On-Road 140 11-29-2012 09:45 AM
