Old 02-02-2012, 12:58 AM   #1
sagejyoung's Avatar
Default SWEEP vs SOREX
hi all i was wondering if there was any knowledge on SWEEP and SOREX tyres for asphalt racing in mod and 13.5 racing?
how do the two tyres compare with consistency and wear?
sagejyoung is offline   Reply With Quote
Old 02-02-2012, 01:34 AM   #2
I would definitely go for Sorex. IMHO, Sweep tires are very inconsistent. I usually race on asphalt, 4-6.5T motors
vhmlaw is offline   Reply With Quote
Old 02-02-2012, 01:41 AM   #3
sagejyoung's Avatar
yea seems the guys at the local track are also into sorex tyres! was asking cause the sweep tyres from what i found are cheaper than the Sorex and perhaps there was an opportunity there.
Old 02-02-2012, 02:10 AM   #4
wollow86's Avatar
Sorex is the go. I've tried sweep and sorex 36 and the sweeps don't have as much grip and don't last as long.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-02-2012, 02:28 AM   #5
Professor's Avatar
Default tyres
cant comment on sweeps,have never used them but have used sorex for about 6 or so years & have found over the last 10 mths or so they dont seem to be as good as they used to be both for wear & grip(this is only my opinion of course)
have recently switched to ride tyres & so far have found them to be a very good all round tyre,also cheaper than sorex
this is using them on painted concrete surfaces outdoor ranging from med to high grip levels
VBC RACING AUS--HOBBYWING--RC MAKER--
MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 02-02-2012, 02:47 AM   #6
sagejyoung's Avatar
sounds like it worth giving it a bash, thanks prof
Old 02-02-2012, 02:50 AM   #7
wollow86's Avatar
I've tried the Ride RE36 Premounts, and I cant make up my mind on them. They were slippery to start with, and seem to take a long time to come up to temperature in a run. But they last so long! And as they get older they seem to get better...
Are you doing anything special for prep using the Rides? I'd like to swap for cost reasons.
Old 02-02-2012, 03:05 AM   #8
It depends.
Our national federation allows only 36 rated tires during its events.
This means that we have to use 36 tires during summer and winter.
Sorex 36 tires do not seem to work well in the winter while you can get a decent amount of grip with 36R sweep even in the winter.
Of course this a special case and normally one would never use 36r tires when it is 5degrees C outside but I thought I should share my experience.
taz00 is offline   Reply With Quote
Old 02-02-2012, 04:40 AM   #9
Professor's Avatar
Default prep
clean with simple green between each run & use warmers about 60deg for about 20mins prior to run
Old 02-02-2012, 05:27 AM   #10
jake95's Avatar
Trader Rating: 27 (100%+)
sorex are good but dont last as long in mod then muchmore's or ride's the muchmore and ride tires are cheaper and are faster or just as fast
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 02-02-2012, 05:28 AM   #11
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Funny, as we have experience the opposite !
Sweep to be much more consistent and provide traction. Especially on colder days.
Last year we had any 36 tyre and still most people used the sweep.
I'm talking about the SW4-36R or SWP-36R with yellow green insert
Tracks are big, and usually not good traction although we raced same day with 1/8th formulas...
I did have some strange behavior on exp 36+ but it was bad batch
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 02-02-2012, 06:29 AM   #12
RC MARKET's Avatar
no other choice ,
Sorex only !
RC MARKET is offline   Reply With Quote
Old 02-02-2012, 06:41 AM   #13
Sorex are the quicker of the two, but as an earlier poster mentioned, the quality may not be as good as they once were.
If I'm correct, I believe they are made close to where the Japanese Tsunami hit last year, so they have had to get them manufactured elsewhere - possibly the reason for the downturn in quality?
However, I may be wrong!!
But on any given day, the Sorex tyres will be quicker than Sweeps.
Mb3195 is offline   Reply With Quote
Old 02-02-2012, 07:38 AM   #14
Pattojnr's Avatar
Trader Rating: 19 (100%+)
last 2 weeks i have done some testing. S411, 3.5T with boost and turbo.
i have tried many tyre.
Edge 36R
Solaris M and H
sweep 36R
Sweep 40R
Sorex 36
Ride 36R
all tyres new, all tyres about 20 mins with warmers.
Edge gave me 16.9
Sweep 36R 16.5
Sweep 40R 16.2
Sorex 36 15.6
then following week
same track different conditions
Solaris M and H , i pulled the car off the track, or the marshall did.
Sweep 36R 17.2
Sweep 40R 16.9
Sorex 36 16.7
Ride 36R 16.2
for our track, we have used sorex 36 most of last year. this was our controlled tyre for the Nationals. they definaltey work well. however, our track, 3rd run, and they just cant cut it. they are slow. First run on sorex and i dont think you will find a better tyre.
Ride 36R
times i thaught were slow, 17.0 16.7 and i think after the 6th run with the tyres 16.2 . i did 8 runs with the rides and also had others use them to try.
and i got them back i think after 10 runs, and still was able to hit 16.5 . these tyres just last. they are slowish to start with, but after a couple of runs, they just get faster each time. so count up the costs. Sorex for the day maybe 3 sets of tyres. Rides, used them all day, and still can be used. i am sold on Rides.
but as far as sweep, i was very surprised that Sweep40R were faster then the 36R. again the sweep40R did last about 8 runs before they tapered off. but for Sorex and 3rd run thats it. is a huge cost to race at the pointy end. i think Rides are just as fast , specially using paragon Fx2.
just my findings over the last 2 weeks or so.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-02-2012, 08:00 AM   #15
CypressMidWest's Avatar
Edge 36R
Solaris M and H
sweep 36R
Sweep 40R
Sorex 36
Ride 36R
Edge gave me 16.9
Sweep 36R 16.5
Sweep 40R 16.2
Sorex 36 15.6
then following week
Sweep 36R 17.2
Sweep 40R 16.9
Sorex 36 16.7
Ride 36R 16.2
Ride 36R
Best post on this thread. Results, rather than opinion..... thank you....
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Sweep Racing Tires 1/10th Sedan thread SweepRacingUSA Electric On-Road 755 09-10-2017 10:36 AM
Muchmore Tires - Sweep vs Absolute bluesxman Electric On-Road 8 07-27-2009 06:04 PM
SOREX vs VTEC vs SWEEP yokemad Electric On-Road 13 08-08-2008 06:44 AM
