Old 02-01-2012, 08:30 AM   #1
Default Help with Pan car gearing
I have two cars RC10 L3 and a Bolink with same spur gear, from the Stock RC10 L3.
The Bolink is a 13.5 Novak w/XBR ESC . The L3 has 5.5 Novak w/GTB ESC.
Can anyone recommend the optimum tooth pinion gear for these? I was trying to Find Novaks chart, but no luck.
Thanks.
cantbuytime is offline   Reply With Quote
Old 02-01-2012, 10:14 AM   #2
anthony153's Avatar
Here's a link to a chart. Pan car gear ratios are determined by the tire diameter. One thing I can tell you is that a 5.5 is crazy overkill for any pan car on any surface.
http://www.snowbirdnationals.com/newthunder/Rollout.pdf
anthony153 is offline   Reply With Quote
Old 02-01-2012, 12:45 PM   #3
Smile Re...roll out
Try Gear chart.com
THEBIGBULL is offline   Reply With Quote
Old 02-01-2012, 12:54 PM   #4
odpurple's Avatar
Thanks.
Try a roll out of about 70mm for the 13.5 and 30mm for the 5.5 for a starting point. You'll probably be able to go up.
BTW, 4.5 motors in 1/12th mod are quite common. Hard to control for the average racer, but common
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 02-01-2012, 01:14 PM   #5
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Im not average I kind of like it when my car tumbles down the straight in the pits into peoples faces!
Josh-n-ya is offline   Reply With Quote
Old 02-01-2012, 03:47 PM   #6
LMFAO
I wasnt planning on running the 5.5 motor but its that or a 4.5.. Probably gonna go 8.5 or something later on. Thanks everyone for your help.
CRC 1/10 Pan Car Doodad Electric On-Road 4165 11-01-2017 02:02 PM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
