Old 01-30-2012, 11:26 AM   #1
Default Anti dive
I've seen a lot of setups recently with people running a bit of anti dive at the front, normally 0.5mm difference.
In real terms, what does it actually do to the handling of the car - and more importantly, what are the pro's and con's?
Mb3195 is offline   Reply With Quote
Old 01-30-2012, 11:36 AM   #2
sosidge's Avatar
More response when initiating a turn off power, perhaps slightly less maximum grip, worse over the bumps.
Old 01-30-2012, 11:38 AM   #3
Lessen's Avatar
Send a message via MSN to Lessen
Putting anti- dive in your car creates resistance against load transfer to the nose. It generally will make the car push on entry. I actually tested this Sat. to see if I liked it or not but my test was too aggressive with the amount. The next club race I plan to test the difference between 0 dive and more caster vs. My current caster setting and a bit of anti- dive.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 01-30-2012, 04:30 PM   #4
Skiddins's Avatar
I have normally seen other drivers this run on high traction tracks to help smooth out the steering and prevent it from 'hooking'.
Dont forget, if you add the shim at the bulkheads you will also reduce caster.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-30-2012, 08:37 PM   #5
TryHard's Avatar
Anti-dive is generally used to make the car more stable under braking, as it helps to resist extreme pitching.
What Skiddins notes is also a very key point...
On most cars, where you set castor by the c-hub, changing the arm to include Anti-dive also reduces the castor angle, and raise the roll centre..so you get a combination of effects.. hence why, usually, adding Anti-dive also makes the car more responsive off centre, but feel to have a little less in the middle.
On the A700 (and other cars with ball joint suspension), because you can set the castor independently of other settings, you can remove the additional effects of adding anti-dive, making the car just stronger on the brakes.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-30-2012, 11:52 PM   #6
HiH
Ed
And I do have a a700 so think I'll give I a go!
Old 01-31-2012, 03:51 PM   #7
Chaz955i's Avatar
HiH
Ed
Thanks Ed. Your explanations are always complete and easy to understand. Good stuff as usual.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
How you guys setup anti-dive/squat?? 05forfun Electric On-Road 8 01-27-2009 03:02 AM
