Old 01-30-2012, 06:46 AM   #1
RC MARKET's Avatar
Default LiPo Battery True C Rate !!
Many Battery Label mark up C rate & Mah
Same Intellect-IP OEM , can mark up to 75C 7200mah !
ORION 45C battery mark up to 90C !
RC MARKET is offline   Reply With Quote
Old 01-30-2012, 08:02 AM   #2
Matt Howard's Avatar
until there's an industry standard way to test C rate the manufacturers/relabelers will just throw whatever they want on their packs. Unfortunatly it's the consumer who loses in this.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-30-2012, 08:02 AM   #3
Say What?
MarcusEngdahl is offline   Reply With Quote
Old 01-30-2012, 09:14 AM   #4
taz00 is offline   Reply With Quote
Old 01-30-2012, 09:52 AM   #5
Many Battery Label mark up C rate & Mah Same Intellect-IP OEM , can mark up to 75C 7200mah !
ORION 45C battery mark up to 90C !...
Could you tell use what the internal resistance is for "each" cell in both LIPO packs ???
Lazer Guy is offline   Reply With Quote
Old 01-30-2012, 09:57 AM   #6
defcone's Avatar
Trader Rating: 15 (100%+)
Funny you say that and you don't sell either batteries.
defcone is offline   Reply With Quote
Old 01-30-2012, 10:16 AM   #7
broscience here but....
my reedy 60c & revtech 65c are much punchier than my orion 90c
tis marketing, imo run what the local fast guys are running.
Shortbusallstar is offline   Reply With Quote
Old 01-30-2012, 10:40 AM   #8
Trader Rating: 18 (100%+)
Soon there will be a way for you to be able to test them yourselves and then decide.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-30-2012, 10:47 AM   #9
Trader Rating: 38 (100%+)
What do mean soon? There is already a way to test them if you feel the need. Get a Castle ICE airplane ESC, put a motor and prop combo on the bench and test away. The castle controller can do data logging so you will have a plot of voltage/watts over time. Comparing these plots will let you know which batteries perform better under load. As for C ratings....advertising gimmick at best since there isn't a standard to test to.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 01-30-2012, 10:48 AM   #10
RC MARKET's Avatar
unknow why they are mark up label C rate ?
in this moment battery factory in China , some material is from Japan ,
can made 60C , around 6500-6800 mah only !
But market had 65C 70C 75C & 90C Now !!
Old 01-30-2012, 10:52 AM   #11
banquer's Avatar
Pleaseeee, tell us moreeee!
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 01-30-2012, 11:12 AM   #12
FB SMC Racing for some info. Details are being worked out but it should be announced soon.
Old 01-30-2012, 11:18 AM   #13
martymiller's Avatar
That's it, after 5 minutes in Illustrator I'm jumping in the battery game. Here's my label or how realistic any label is.
martymiller is offline   Reply With Quote
Old 01-30-2012, 11:18 AM   #14
Regional Moderator
CarbonJoe's Avatar
Hmm, since most batteries are rated for continuous discharge (except Orion, which appears to be using the burst discharge rate), 7200mAh, 75C = 540A continuous. Too bad the wires and/or solder connections will melt before that rate is maintained. Short runs of 12 awg wire is only rated for a max of 60A.
http://www.rowand.net/Shop/Tech/WireCapacityChart.htm
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-30-2012, 11:27 AM   #15
RC MARKET's Avatar
Yes ,
20 Amps charge battery , 12awg wire & connector will had warm
(WTS)EXtra Unit Vista Power EV-622A 10A C 5A D&Giant Power 7.4V 5200 50C Hardcase Lip sangyi41 Malaysian Forsale-Trade 12 06-27-2011 01:12 PM
Thunder Power Rc 40C 5000 Lipo ThunderPowerRC Electric On-Road 439 02-25-2010 04:35 PM
C Rating battery craze! True or untrue!! Bulldawg RC Electric Off-Road 236 03-11-2009 01:44 PM
