Old 04-13-2005, 08:10 AM   #106
Hi,
Here's a rubber tires for dummies question. A new indoor asphalt track has opened near my part of the world, and it's a great facility with large amounts of traction. For instance, watching a heat of fast guys last weekend, I would have bet I was looking at a race being run on carpet with foams. I also witnessed plenty of people traction rolling throughout the day as well. So, over the course of my three qualifiers, my car's handling began to degrade. By that, I mean it went from having a decent balance of front/rear bite (both lateral and forward) to not having enough bite anywhere and consequently doing a lot of sliding/diffing out. Not un-driveable, but not as good as it had been. I tried some suspension changes before the main, and they didn't affect much. Finally, I put on a new set of CS-27s. I ran them a couple laps to break them in and it was a night and day difference. The car handled better than it had all day. The set of CS-27s I took off the car had about 15 runs (of stock sedan) on them. They looked somewhat worn in places, but not horrible. Given that this surface has such high grip, my (faulty) logic would have dictated that anything even resembling a rubber tire (e.g. a couple of cut-up balloons and electrical tape - j/k) would have worked as good as the next tire. But, that was not the case. Does anyone have an explanation of what has actually changed in the tire rendering it "worn out?" (e.g. rubber isn't flexible anymore after so many heat cycles, the uneven tire surface doesn't hook up anymore, etc.) Just curious. Sorry if this has been discussed previously. Thanks.
Andy
adavid is offline   Reply With Quote
Old 04-13-2005, 10:48 AM   #107
Send a message via AIM to Adam Hartzell
adavid--When a tire heats up the chemicals that make up the compound sort of mesh together and that is what causes the tire to become sticky. If the tire becomes real hot (ie. racing conditions) some of the chemicals will seap onto the track. Very similar to the way a foam tire degrades becaust the foam sticks to the track surface. After so many runs a rubber tire will no longer have that proper chemical make-up that allowes it to stick so well. 15 runs sounds close to the life of a CS-27 depending on how hard you are driving the car.
I have a track just like you described near me (indoor asphalt very high bite). I prefer to run a 32 compound tire as it dosen't break down as fast. Although it dosen't stick as well.
Hope this answers your question.
Adam Hartzell is offline   Reply With Quote
Old 04-13-2005, 11:08 AM   #108
Adam,
Thanks for the explanation. I can buy that! I am thinking of trying the CS-32 option myself. I'm hoping that on-power, the CS-32s will slide laterally a bit more, instead of digging in like the CS-27s sometimes do (the high-bite-induced digging in seems to promote some inside tire lifting and diffing out), providing better forward bite off the turns. I guess this is one reason spools are popular.
Andy
p.s. Any way to scrape all those chemicals off the track and resell them? Ha!
Old 04-13-2005, 11:19 AM   #109
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If you're getting 15 runs on a set of 27's, you're getting good wear. I run them about 5 and their done. But that's also outdoors running modified. Adam's description is perfect.
Jon Kerr is offline   Reply With Quote
Old 04-13-2005, 11:21 AM   #110
Korey Harbke's Avatar
The 32 is actually a pretty good tire too. The temp range isn;t as wide in my opinion, but on those REALLY hot days they last alot longer. Your car free's up too!!!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-13-2005, 11:26 AM   #111
rayhuang's Avatar
In karting-when possible we would season tires. One short hard run-this would get the tires sticky compound to change and settle back down-then let them sit overnight before running again. The idea was that this procedure would allow the tire to perform at a higher level for much longer during a race and also over a longer number of heat cycles.
I dont think RC rubber tires are even 0.001 as sticky as a kart tire-but maybe if anyone had the time or budget to test this-it might have some merit.
Ray
Old 04-13-2005, 11:32 AM   #112
Cool, it's just getting a quick heat cycle in them. Might be something to try if one is bored lol. Maybe I'll do it this weekend!
-Korey
Old 04-13-2005, 11:34 AM   #113
rayhuang's Avatar
-Korey
I temped my tires on carpet and they were only 90 degrees on the left front and 80 on the other 3. SO to counterpoint myself, I wonder if any chemical process occours in these tires at that low of temp. Outdoors I am sure they get a lot hotter though.
Old 04-13-2005, 11:36 AM   #114
Jon Kerr's Avatar
Ray
I kind of did this with Sorex tires once. I had two brand new sets and I went out and run 5 laps on one set to scuff them and get them warm, pull it in, change tires, and do it again to a second set. They seemed better at the start of their race but I didn't notice any extra life. But like I said, I only did it once. You'd need to do it much more to find out if there's any consistancy to it.
Old 04-13-2005, 11:38 AM   #115
SCML's Avatar
This technique is used in full size racing also. Tires need a gradual build up of heat over about 5 or 6 laps (full size), going about 9/10ths the lap before coming off the track, then storing the tires for a minimum of 24 hours, preferably a week. Tires have a longer competitive life this way. Going hard out of the box, or not cycling them properly kills them quick (more wear, blistering and short competitive life).
Rubber is rubber, and this can't hurt in RC tires. They don't get as hot as a full size tire does, but I generally try to get a break in run of a bout 3 minutes on each new set. Then I pack them away to use for a race a few days or a week later. I don't have any concrete data to support longer life and more consistancy with RC tires though.
A psuedo heat cycle could be performed with tire warmers also. The Tire Rack sells a heat cycling service with sets of race tires which is basically what you could do with some tire warmers.
Mike
SCML is offline   Reply With Quote
Old 04-13-2005, 11:38 AM   #116
Jon Kerr's Avatar
I've temped my tires at 140F on hot days with track temps over 150F.
Old 04-13-2005, 11:41 AM   #117
Jon Kerr's Avatar
SCML- that's a good idea. I'll try putting new tires on warmers when I get them at home before I go to the track and see how well it works.
Old 04-13-2005, 11:44 AM   #118
Yeah, its not abnormal to see my tires get that hot either lol.
-Korey
Old 04-13-2005, 05:35 PM   #119
Jon Williams's Avatar
Cool thread, guys.
Any recommendations on what temp and duration to set the warmers at for cycling through the sets? We're still in the upper 50s/low 60s on race days and the track temp gets around 100* F max.
Jon Williams is offline   Reply With Quote
Old 04-13-2005, 06:08 PM   #120
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
I was told when working with warmers 80 degrees is a nice temperature to get the tires up to....that what I am going to use as a starting point and adjust from there...
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
M18 Pro & Rubber Tires BIGTACO Micro and Mini Scales 9 06-14-2012 08:18 PM
Foam Tires for Dummies swopemike Electric On-Road 51 04-14-2008 10:59 PM
best rubber tires rc_speed Electric On-Road 11 05-02-2007 10:37 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
FS: Rubber TC Tires AZ_Ron R/C Items: For Sale/Trade 3 01-12-2005 10:17 PM
