Old 10-06-2006, 01:03 PM   #226
rayhuang's Avatar
Originally Posted by PW
The reason rotating tires doesn't really work is due to the insert. The insert shifts and breaks down slightly faster on the tires that would be the outside tire at the end of a straight or any highspeed turns
Cool guys!! learnin, always learnin somthin!!
Old 12-06-2006, 07:12 PM   #227
snopro31's Avatar
Trader Rating: 36 (100%+)
So can you run a set a couple of times them take the fronts off and move the rears to the front and put new ones on the rears? then your only putting on a pair instead of all 4 or is it better to replace all 4 at the same time?
snopro31 is offline   Reply With Quote
Old 12-06-2006, 08:01 PM   #228
AdrianM's Avatar
If you are club racing just run used tires in qualifires and new or newer tires in the main if you have them.
If you are at a big race with a 2 set of tires limit and you have to run 3 quals and a single main then rotating tires as you said would work out. If you run Stock or 19T its all good. If you run Mod you have to make sure your car setup will give you the steering you need.
Adrian Martinez
Old 12-07-2006, 05:35 PM   #229
snopro31's Avatar
I am thinking about big races that have spec tire but no limit on amount of tires. seeing if its better to run new every run or not really needed.
also is there anything to do to tires be you run them ? most of the take off premounts have a seam type of thing down the middle does it not make a difference or is there stuff to do to make the tire race ready ?
Also i assume oneways centre and front are the way to go for rubber on carpet?
Sorry for all the questions we dont run rubber tires (i wish we did ) but i am going to a race that i will need to run rubber tires for 19T. I just want to start to practice now and learn as much as i can.
Old 04-26-2007, 09:19 AM   #230
swopemike's Avatar
Is the RP24 tire going away?
Will there be another replacement?
Is the CS22 the next best replacement?
My LHS normally carries these two but cannot get RP24GL any more.
We run some night races under the lights and was looking for a "cool summer night" tire. Sometimes RP30 seem to lack enough grip in these conditions.
swopemike is offline   Reply With Quote
Old 04-26-2007, 11:51 AM   #231
AdrianM's Avatar
The RP24 and RP24GL are still available. There are no plans to discontinue them that I am aware of and I am the US importer.
We have a few hundred RP24's in stock (4pk tires with no insert) and ~1000 RP24GL's (4pk RP24 premounts) in stock right now.
Adrian Martinez
Old 04-26-2007, 03:13 PM   #232
jag88's Avatar
Does anybody know how we ended up with the diameter and width of tire we are currently running? It would nice to have a wider and maybe a smaller diameter tire ........ yea I know, new tooling cost would be HUGE .
jag88 is offline   Reply With Quote
Old 04-26-2007, 03:27 PM   #233
adamge's Avatar
jag, what's your thinking on that? You like the F1 tire look?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 04-26-2007, 04:07 PM   #234
AdrianM's Avatar
Width History
Back in 1995 we used to run 26mm and 30mm tires. The wider tires just added rolling resistance so guys started running 26mm tires all the time.
Yokomo figured out that you could make the car turn harder and reduce the rolling resistance even more by going to 20 and 22mm tires. Their 22mm Medium Sprints were awesome back in the day. The problem is that they looked goofy...like a car with motorcycle tires on it.
ROAR and IFMAR got together and said to make the car look more scale 24mm was the narrowest legal tire. Since narrower tires were always faster all modern racing tires are 24mm.
Diameter History
Tamiya made the first sedans. They set the standard for rim and wheel diameters. The first racing tires were 68 to 67mm in diameter. HPI went a little lower profile with its Super Radials and Belted Slicks and Yokomo went a little smaller with its Hot Laps tires.
Most modern racing tires are 66-64mm in diameter. Sorex are the biggest of the top level racing tires and Take Off's RP's are the smallest in diameter.
Adrian Martinez
Old 04-26-2007, 05:11 PM   #235
adamge's Avatar
That's good stuff.
-Nietzsche
Old 04-26-2007, 08:14 PM   #236
jag88's Avatar
Thanks Adrian.
Old 04-26-2007, 08:39 PM   #237
Trader Rating: 198 (100%+)
Adrian, Please remind me on the sauce schedule for RP30's and Sorex tires. For a 70 degree day.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-27-2007, 07:58 AM   #238
AdrianM's Avatar
If the track is less than 32*C (90*F) run a 50/50 mix of Trinity Tire Tweak and Paragon FX2. Bake with tire warmers at 60*C (140*F) for 20 min. Remove the warmers and wipe the tires if there is any stuff left on them....go race.
If the track is hotter than 32*C (90*F) run straight Trinity Tire Tweak or if you need more steering Hybrid Dip. The rest of the proceedure is the same.
If the track is cold or if you race at night run straight Paragon FX2. The rest of the proceedure is the same.
When you get back to the pits after you run clean your tires with Trinity Buggy Grip with clean paper towels until no more dirt comes off the tires. Never put traction compound on dirty tires. Starting with clean tires makes the saucing process more consistant.
Do not use motor spray to clean your tires. Traction compounds are oil based. Motor spray removes oils and thats not a good thing for rubber tires.
Adrian Martinez
Old 04-27-2007, 10:18 PM   #239
quantum's Avatar
what are your thoughts about using simple green to clean tires?
quantum is offline   Reply With Quote
Old 04-28-2007, 05:47 AM   #240
Great info!
Buggy Grip is a solvent based not oil based isn't it?
www.donatelife.net
M18 Pro & Rubber Tires BIGTACO Micro and Mini Scales 9 06-14-2012 08:18 PM
Foam Tires for Dummies swopemike Electric On-Road 51 04-14-2008 10:59 PM
best rubber tires rc_speed Electric On-Road 11 05-02-2007 10:37 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
FS: Rubber TC Tires AZ_Ron R/C Items: For Sale/Trade 3 01-12-2005 10:17 PM
