Old 08-29-2006, 08:22 AM   #211
rayhuang's Avatar
On any surface, do you guys usually sauce front and rear tires full and tune around that, or do you sometimes sauce say half front, full rear to gain or lose steering?
Old 08-29-2006, 08:30 AM   #212
RCGaryK's Avatar
Ray, are you going to run Rubber at the Halloween Race at the Gate?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 08-29-2006, 08:37 AM   #213
rayhuang's Avatar
yes, no, maybe!! It depends on if I sell all of my TC stuff after Vegas or hold onto a TC for the HC. I also still want to do the TCS race at TWOH so maybe I'll get a EvoV or another 415, but with a diff!!!
Old 08-29-2006, 08:39 AM   #214
RCGaryK's Avatar
What chassis are you running now????
HorizonHobby.Com
Old 08-29-2006, 08:42 AM   #215
rayhuang's Avatar
Xray FK04 with BMI 350 chassis. Long story short-I am fastest with this older TC for some reason and so I went back to it and am immediately comfy and runing well with it. Of course I have to run with Goetz, Herrmann, Wise, Chicky-so me running well is always a relative term....
Old 08-29-2006, 09:06 AM   #216
RCGaryK's Avatar
That car is basically a 414M2, which one of the Wisconsin boys went back to and is much more comfortable with it. He had an Evo 3 Surikarn and (my old) 415. He could bever get as comfortable with those. There's something to that "Polar moment of inertia" thing in a saddle pack car.
HorizonHobby.Com
Old 08-29-2006, 09:10 AM   #217
rayhuang's Avatar
I think the 04 will make a fine rubber tire car too. I need to test that theory soon me thinks!! Finally a use for thise white and yellow springs!!
Old 08-29-2006, 10:14 AM   #218
With all the possible tire/insert combinations why does it seem all the big races require a handout tire like the premounted Takeoff 27's? Do they do the same with foam or do people use whatever they want? I'm just curious cause I think rubber would be faster if we weren't limited this way.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 08-29-2006, 10:18 AM   #219
RCGaryK's Avatar
They spec the rubber tires to keep costs down. When you start experimenting with inserts it can get costly
HorizonHobby.Com
Old 08-29-2006, 12:26 PM   #220
ottoman's Avatar
R/C Tech Charter Subscriber
Boy... I remember those days... you had 4 different tire compounds with 3 different foam inserts in each compound... and maybe a couple of different rim types..... big money Spec premounts are the ONLY way to go in rubber racing
ottoman is offline   Reply With Quote
Old 08-29-2006, 01:02 PM   #221
We are having this problem now with the choice of any tyre/insert wheel, i have decided on a sorex 28 tyre for the series as these seem to work and i think i will use the jb foam inserts but does anyone know what thickness of insert seems best for the sorex tyre on a std 24mm wheel i would say thick as sorex usually have a large airgap but if anyone has found anything else please share your findings.
LEE UK is offline   Reply With Quote
Old 10-06-2006, 09:16 AM   #222
rayhuang's Avatar
Well-I am back on my rubber tire kick again, this time with much beter results.
I am curious to know how you guys rotate tires? Since I run half dope on fronts and full dope on rears, will a run or two after a good cleaning-swapping frnts to rears be doable?
Also-I assume rears last longer than fronts so its possible to make rears fronts-at least for a run or two after fronts are in the trash bin?
Also-I was told the RP30GL's have a limited number of good runs on them. Does it help to let the tires rest a long time between runs-or doesnt it matter. Last time I ran three runs within 45 minutes on one set of RP30's and I think the last run (though my fastest by a big margin) I was starting to feel the tires start to lose grip. This is on new CRC fastrack.
Old 10-06-2006, 09:37 AM   #223
Mike Haynes's Avatar
I never really rotated mine on carpet, for club racing i marked the corner of the car it came off of and always replaced them there.
At an outdoor race this summer we were running on a banked track, we could not rotate tires (if we did the car had 0 traction)...strange but it got me in the habit.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-06-2006, 10:20 AM   #224
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I've heard that as well. If you reverse the rotation of the ire it wont have any grip but you can swap from front to rear as lonf as they stay on the same side of the car.
Seaball - Not sure on the swapping with different levels of traction compound. Sounds like your gonna have to try it out and let us know.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 10-06-2006, 12:38 PM   #225
PW
PW's Avatar
Send a message via AIM to PW
The reason rotating tires doesn't really work is due to the insert. The insert shifts and breaks down slightly faster on the tires that would be the outside tire at the end of a straight or any highspeed turns
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
M18 Pro & Rubber Tires BIGTACO Micro and Mini Scales 9 06-14-2012 08:18 PM
Foam Tires for Dummies swopemike Electric On-Road 51 04-14-2008 10:59 PM
best rubber tires rc_speed Electric On-Road 11 05-02-2007 10:37 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
FS: Rubber TC Tires AZ_Ron R/C Items: For Sale/Trade 3 01-12-2005 10:17 PM
