Old 06-09-2005, 04:15 PM   #151
Trader Rating: 18 (100%+)
CS27s at 160?!?!?!?
Ok, I'm game. I'll try it this weekend at Ripon.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-09-2005, 04:21 PM   #152
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've done it too. Parking lot race in the dead of summer in Riverside with temps of 150F we were trying Sorex36's and couldn't get them too hook up at all, tossed on a set of 27's just out of curiosity and they were strapped.
Jon Kerr is offline   Reply With Quote
Old 06-09-2005, 04:53 PM   #153
snopro31's Avatar
Trader Rating: 36 (100%+)
Originally Posted by AdrianM
Paragon GFX cold to cool weather and at night
Paragon FXII or Niftech for cool to warm weather
50/50 mix of FXII and Tire Tweak when its hot.
Straight Tire Tweak when it Blazing hot
Ok so what range are these temps then? This is basicly what i meant. i dont know what blazin hot to you is . your hot to me could be blazin hot to me.
Thanks for the help
snopro31 is offline   Reply With Quote
Old 06-09-2005, 08:24 PM   #154
speedxl's Avatar
R/C Tech Charter Subscriber
Thanks for the help
take into consideration what our (Adrian M and I )previous posts say you can figure it out easily. hot is 120 up to 150 cooler is 100 to 120 and cold is less then 80 which is rare in florida even at 11pm at nite.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-09-2005, 08:40 PM   #155
snopro31's Avatar
Originally Posted by speedxl
We are down and florida for us a cool asphalt temp usually 110 to 120 after that generally we see temps upto 150! We get 80 deg sometimes maybe 6 days out of the year when ambient temps are in the mid 60's to mid 70's.
Well thanks and sorry it sounds as if i offended you , but i did not find it out from this post. cool temps are 110-120 , so mild temps are? hot is ? super hot i assume is the 150 . 80 and below is cold. so from 80-110 is what?
Old 06-09-2005, 08:52 PM   #156
speedxl's Avatar
dude I am not offended its just obvious your answer is ding ding ding!
less then 80 degs is cold for us.
upto 120 is cool (less colder then cold)
and over 120 makes your gonads sweat and tires bake!
(disclaimer) Its a joke ok! if anyone is offended by it I appologise ahead of time!
Old 06-09-2005, 09:23 PM   #157
Send a message via AIM to Adam Hartzell
Hector-- I tried calling ya but I can't seem to reach anyone outside of MI. Damn Nextel
Anyway try calling me on Fri if you got time.
Adam Hartzell is offline   Reply With Quote
Old 06-09-2005, 10:05 PM   #158
Shouldnt this thread be renamed, Rubber tires ARE for dummies
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-09-2005, 10:27 PM   #159
ChadCapece's Avatar
Originally Posted by adavid
3. Some tracks lend themselves to one-ways better than others. My understanding is that tracks that require braking to be fast aren't good candidates for one-ways. One-way tracks are described as "flowing" which I take to mean few or no turns require much, if any, braking to be fast. Given that, how would you categorize the asphalt outdoor track at Toys For Boys in Georgia? For fun, pretend the Spool Monster has eaten all of your spools (hey, it could happen!). Would you use a one-way there or a diff? How does the amount of traction play into things? Thanks.
Andy
http://tfbraceway.com/modules.php?na...showpage&pid=4
Funny you mention that. I was down at TFB and the spool monster ate my spool just before race time. I was running 19turn and switched to a one-way just before race time. I had a ripping car before the spool monster, and with a one-way it just wouldn't work right in tight turns. IDK if it was the slickness of the asphalt or what, but I know a spool would have shaved off atleast a half second on each lap. I would suggest a tight/locked diff. That track has a poorly placed back corner. The wood sticks out to grab those front tires. So if you can help it, carry an extra spool b/c a tight diff will break if you catch that back wall.
ChadCapece is offline   Reply With Quote
Old 06-09-2005, 11:30 PM   #160
snopro31's Avatar
Yes this part i understand my question is more or less about listing 5 different ranges for the traction compound but you only talk about 3 differtn ones when asked here is basicly how i understand but i am trying to make sure i am correct. please let me know if i am or not
Paragon GFX cold to cool weather and at night 0-120 as 120 is still cool on your list.
Paragon FXII or Niftech for cool to warm weather 120-135
50/50 mix of FXII and Tire Tweak when its hot. 135-150
Straight Tire Tweak when it Blazing hot 150+
Old 06-10-2005, 12:41 AM   #161
speedxl's Avatar
Dude I am telling in What Florida temps mean to us we actually only get those three. Its either cold or hot.
Dude if less then 80 is cold (Paragon GFX cold to cool weather and at night)!!
upto 120 is cool to warm (Paragon or niftech)
above 120 to 135 50/50 .
above 150 straight tweak.
Look if you use common sense you'd figure whats in between! Sorry man I am not trying to be a jerk but the answer is there. I didnt think I needed to break it down by degrees precisely.
Plus You only need to worry about cold and cooler on our scale. In your neck of the wood anything over 125 is probly never!!!
Also Adrian listed 4 not five. The funny thing is you had it figured out on your post. Florida is funny with weather the further south the closer to the equater yet close enough to the north to get wierd weather. We dont get four seasons here. Its summer and fall without changing of the leaves. It cools down a little to low 50's and maybe 5 to 6 days of high 40's and thats in the mornings or evening because when the sun comes out its a low 70's day. with track temps around 80 ( cold for Florida)!
Hope this helps! THis has been your meterolegist SpeedxL !
Old 06-10-2005, 01:42 AM   #162
Hi Guys,
I think this is a wonderful thread.Learn lots of stuff from here.
Think you guys are talking about blazing hot.I don't know how hot is blazing be.
But I come from Singapore and is really really blazing hot here.All the tires that you guys suggested eg Sorex 36 are for night racing and we use Sorex 40 for the day.I don't know how to convert F to C.But Temps can get as high as 36C here around the equator.
Ben.C is offline   Reply With Quote
Old 06-10-2005, 10:34 AM   #163
speedxl's Avatar
Originally Posted by Ben.C
Hi Guys,
36c is equal to 96.8f degree's
Formula for converting! a °C = (4/5)a °Réaumur = [32 + (9/5)a] °F.
Lucky for us there is conversion tables all over the net!
Old 06-10-2005, 03:24 PM   #164
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Heck 96.8 is cool weather here in the desert....Singapore is just to blasted humid....You take a shower and you get out you feel like you need another shower just to wash off the sweat you just accumulated...
But as for Blazin He is refering to tracks that the track itslf is hotter than 150* if ever this happens, pack up go home...Your sweating more than racing..LOL
But yes in Souther California I have seen track temps of 155* but that was a real scorcher for like 6 days strait of 105*+ it was stupid hot.....
Stephen <><
If you aint using tweak (tire type) you ain't winning...LOL
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-10-2005, 08:47 PM   #165
Suspended
whats the temp range for a losi yellow with no traction compound or paragon ground affects
THE_REAL_FROBOY is offline   Reply With Quote
M18 Pro & Rubber Tires BIGTACO Micro and Mini Scales 9 06-14-2012 08:18 PM
Foam Tires for Dummies swopemike Electric On-Road 51 04-14-2008 10:59 PM
best rubber tires rc_speed Electric On-Road 11 05-02-2007 10:37 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
FS: Rubber TC Tires AZ_Ron R/C Items: For Sale/Trade 3 01-12-2005 10:17 PM
