Old 06-09-2005, 12:21 PM   #136
rayhuang's Avatar
Thanks Hector.
Old 06-09-2005, 12:34 PM   #137
AdrianM's Avatar
Sorry...I forgot you are from Carpetland. I have the opposite problem you have. I only run Foam once a year at the Snowbirds...lol!
If you have to run Tamiya tires at TamNats you might as well run only Tam tires. For Sedans I hear the Type A is best.
Adrian Martinez
Old 06-09-2005, 12:39 PM   #138
snopro31's Avatar
Trader Rating: 36 (100%+)
Originally Posted by AdrianM
. For daytime asphalt racing that is usually the Take Off CS27GL (all weather), Sorex 36R(hot weather) or the new Take Off RP30GL (warm weather) or RP36GL (hot weather).
Paragon GFX cold to cool weather and at night
Paragon FXII or Niftech for cool to warm weather
50/50 mix of FXII and Tire Tweak when its hot.
Straight Tire Tweak when it Blazing hot
Some great info here Thanks alot. i have a few questions about what aprox is your track temp and/or air temp at each level you state , your idea of cool and mine can be way different an actual temp range to go by would help for track temp and/or air temp. track temp would be best as sun and everything else plays into it and just because the air is XXtemp doesnt make the track the same for that air temp all the time.
snopro31 is offline   Reply With Quote
Old 06-09-2005, 12:58 PM   #139
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I have yet to run carpet. Vegas will be my first time! I'm running rubber classes though. No foamies for me.
Jon Kerr is offline   Reply With Quote
Old 06-09-2005, 01:07 PM   #140
Pro Models's Avatar
Hi Guys,
Our local track is very particular since the asphalt is quite coarse with big gaps in between the stones and its usually also dusty, any ideas of what traction compounds can be used in such a situation.
Bye for now.
Pro Models is offline   Reply With Quote
Old 06-09-2005, 01:29 PM   #141
Big Rigg's Avatar
Generally if it's dusty any traction compound I've tried will just pick up the dust onto the tire... In paking lots I usually just run em dry and try to hang on for the first couple of turns.
Speaking of rubber on Carpet what are some good combos? I know up in Stockton they've had good results with pit 27s with hpi green inserts (think I got that right). I ran TakeOff CS27Ws and they had too much bite after the 3 minute mark...
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 06-09-2005, 01:32 PM   #142
speedxl's Avatar
R/C Tech Charter Subscriber
We are down and florida for us a cool asphalt temp usually 110 to 120 after that generally we see temps upto 150! We get 80 deg sometimes maybe 6 days out of the year when ambient temps are in the mid 60's to mid 70's.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-09-2005, 01:33 PM   #143
speedxl's Avatar
Originally Posted by Pro Models
Hi Guys,
Bye for now.
I'd try wd-40.
Old 06-09-2005, 01:38 PM   #144
Originally Posted by speedxl
If the spool monster ate it I would take a diff and lock it down! I have run there and you do need a spool and if not atleast a diff before a oneway.
There are 2to3 areas where you to slow down too much and if you want to pass someone you'll need brakes there, especially the hair pin at the end of the straight away and the left hander after the chicane section!
Lock that diff dude!
Thanks for the input. I'm also one of these guys who's focusing on Tamiya racing, so that's why I mentioned the spool monster (although now Tamiya makes a spool for some of its cars, I think). Unfortunately, I haven't had much luck locking down the front diff on my TB-02, as the diff screws are kind of weak and tend to shear. I'll have to give it another try and/or use a thicker diff lube.
Andy
adavid is offline   Reply With Quote
Old 06-09-2005, 01:42 PM   #145
speedxl's Avatar
Andy
Andy a quick spool config is take all the diff balls out! clean all the grease off aswell as the diffrings. Take a header card from say a trinity brush package. Glue them to the diff rings tighten the screw down all the way and back it out 1/8 to 1/4 turn so there is less stress on the diff screw. Trust me it works!!
Old 06-09-2005, 01:44 PM   #146
Hebiki's Avatar
Trader Rating: 26 (100%+)
tony... i ran the CS27Ws all around up in gilroy with TQ orange as the traction compound. i left the sauce on there way too long (about 4-5mins) and my car was on two wheels in some of the corners. someone recommended running a bead of glue on the side (to reduce the side bite). and wiping off the TQ orange after 2-3 mins of sitting on the tires.
my car was fine for the quals.. but for the mains.. traction came up like a *&%@*#%
id like to try sorex 28s next time im up there.. but i do like the ease of use with the preglued CS27s
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-09-2005, 01:48 PM   #147
Cool. I will try it. Thanks for your help.
Andy
Old 06-09-2005, 02:59 PM   #148
dizzy1's Avatar
Trader Rating: 24 (100%+)
Adrian-The tire tweek you are talking about, do they still sell that? For some reason I thought they stopped selling it or something. Is the tire tweek 2000 the same stuff?
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 06-09-2005, 03:34 PM   #149
snopro31's Avatar
Hi thanks for the info i hope that AdrianM can confirm that is what he class's as the temps he put down ,as this is what i mean calling it warm and stuff can get fuzzy from one person to another.
I live in canada i call those temps wicked hot
Old 06-09-2005, 04:09 PM   #150
AdrianM's Avatar
Trinity still sells it. Its is quite popular for rubber tires outdoors. Dont forget to get a bottle of buggy grip at the same time. That gets rid of the greasiness of the Tweak during the first few laps.
I race with SpeedXL all the time. His temp ranges are right on. Keep in mind that the CS27 has a huge temp range. We have used it on 60deg F (Reedy Race 2003) to 160 Deg F tracks (Worlds Warm Up 2004) with great results.
I run CS22's when the air temp and track temp are about equal, i.e. at night, and less than 80 Deg F.
Adrian Martinez
M18 Pro & Rubber Tires BIGTACO Micro and Mini Scales 9 06-14-2012 08:18 PM
Foam Tires for Dummies swopemike Electric On-Road 51 04-14-2008 10:59 PM
best rubber tires rc_speed Electric On-Road 11 05-02-2007 10:37 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
FS: Rubber TC Tires AZ_Ron R/C Items: For Sale/Trade 3 01-12-2005 10:17 PM
