Old 01-05-2005, 10:23 AM   #1
Default p2k2pro
hey i was wondering what is a good esc that goes with the p2k2pro because im a new guy and was just wondering cus im getting into electric drifting... so any info would be appreciated
hippykakka is offline   Reply With Quote
Old 01-05-2005, 11:52 AM   #2
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
if your planning on not going to anything faster a novak explorer would be a good chance but if you eventually want to go faster you would want a better esc.
Javen13 is offline   Reply With Quote
Old 01-05-2005, 12:32 PM   #3
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
If your only going into drifting, you cant go wrong with any of the Duratrax Intellispeed line of ESC's. There reliable and very cheap.
Like Javen13 said, Novak's are excellenct also.
Paul_TC4 is offline   Reply With Quote
Old 01-05-2005, 12:33 PM   #4
yeah but are they good with p2k2pro engines???? thats my biggest concern!! like with the 27t out of p2k2???
Old 01-05-2005, 12:42 PM   #5
Paul_TC4's Avatar
Just about every ESC is fine with a 27t stock "motor". The ESC will handle it.
Old 01-05-2005, 12:45 PM   #6
the more $$ you spend the better the esc as in smoother and punchier throttle and braking along with diffrent profiles depending on the type of motor basicly any esc will work with a stock motor like yours but if you plan on getting a diffrent motor in the future you may want to purchase a better esc now ratter having to get a new one when you get a faster motor(if you get one a stock motor is really all you need for driffting).
Old 01-05-2005, 01:29 PM   #7
ok so if i get a yokomo AE96 kit with just yokomo stock motor then any esc will work??? whats a good esc for any motor?? especially 27T p2k2pro??
Old 01-05-2005, 01:34 PM   #8
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
go with the duratrax like mentioned, they are cheap and will last.
RCNitroDude999 is offline   Reply With Quote
Old 01-05-2005, 02:10 PM   #9
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
OK...I think there's some kind of misunderstanding here...LOL
MORE turns = less power...you can use just about any ESC to run a 27T motor.
LESS turns = more power...you need a more expensive ESC to run more powerful motors.
For a 27T stock motor (like a P2K2 Pro, or stock Yokomo), just about any ESC will do the job. If you think you might want to get a more crazy motor in the future, you need to get a decent speed control now...unless you want to buy a cheaper one now and have to buy another (more expensive) one later.
Turbo Joe is offline   Reply With Quote
Old 01-05-2005, 02:25 PM   #10
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Just buy the cheapest controller you see.... You dont' need any fancy features nor the ability to handle LOW turn motors... I don't get drifting, but to each his own.....
I still lurk....
vtl1180ny is offline   Reply With Quote
Trinity P2k2Pro ARM- pls help! sonneteer Electric On-Road 21 07-14-2006 05:46 AM
p2k2pro....from tower pink pac man Electric On-Road 8 11-30-2004 11:34 PM
