Vtx10 with Lrp x12 13.5 help >
Old 01-27-2012, 11:06 PM
narcotiks's Avatar
Default Vtx10 with Lrp x12 13.5 help
The manual on the Lrp motor says not to run timing... But I know that's bs
So is anyone running the same Esc and motor that can give me some help as to what Esc settings and motor timing to use ?!!
And what is the x12's timing straight out of the box? Like in degrees ...??
narcotiks is offline
Old 01-28-2012, 02:56 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
For boosted, run the -10 insert. LRPs have a lot of timing in them, even with the -10 it still has something like 27 degrees of timing.
wingracer is offline
Old 01-28-2012, 02:58 AM
wingracer's Avatar
Scroll down a bit for a timing chart.
http://www.rctech.net/forum/californ...ll-so-cal.html
Old 01-28-2012, 07:33 AM
Is this blinky or boosted?
I ran an LRP X12 17.5 with the Viper VTX10 briefly...
JamesL_71 is offline
Old 01-28-2012, 08:04 AM
narcotiks's Avatar
It's boosted!
So would I be safe and competitive to use profile 7?
Old 01-28-2012, 08:22 AM
wingracer's Avatar
I don't have a viper so can't help you with set-up but the combo of viper with lrp is very competitive, I've been beaten by it a few times.
Old 01-28-2012, 08:27 AM
Originally Posted by narcotiks View Post
It's boosted!
Ive only ran Blinky with it, so I cant be of much help.
But I would start with the 4dot timing insert on the X12 and use profile 7 to start with.... Gear conservatively and go from there.
Old 01-28-2012, 06:53 PM
narcotiks's Avatar
hahaha well I hope it's works out well for me
Whats the maximum temperature for the x12 before it starts getting damadged ? In Celsius please
Okay sweet do you know a thread or anyone who could give me advice with a good speedy setup for this combo?
Old 01-28-2012, 08:51 PM
wingracer's Avatar
They can take over 190f before bad things happen but can fall off in power over 180. 13.5s seem to be able to take more heat without falling off than some of the others so I would say 180. Sorry, don't feel like converting.
