Old 01-25-2012, 06:09 PM   #1
cartix's Avatar
Trader Rating: 33 (100%+)
Default Radshape Stealth RWD Tourer
Not for sale in the USA. It's a hybrid, TC front end with T-Plate solid axle rear.
http://radshaperc.com/Stealth/stealthvideos.html
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 01-26-2012, 12:22 AM   #2
Trader Rating: 30 (94%+)
Ok.
Rocky8333 is offline   Reply With Quote
Old 01-26-2012, 12:28 AM   #3
CypressMidWest's Avatar
Interesting idea. I'm a member of rccircuitcars.com so I've seen this chassis before. It might make for a competitive WGT car, or possibly even a whole new class of rubber tire, RWD TC's. Could be pretty cool, especially wth GT bodies.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-26-2012, 12:30 AM   #4
mailboxck's Avatar
Design looks a bit off. Also, aren't the body posts located too close to each other?
mailboxck is offline   Reply With Quote
Old 01-26-2012, 12:45 AM   #5
Check this vid. The car looks solid, I think it would make a stellar spec chassis.
Old 01-26-2012, 05:01 AM   #6
Regional Moderator
CarbonJoe's Avatar
You just like it because it's basically a 1/12 scale chassis.
This is exactly what this hobby needs, more classes.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-26-2012, 10:05 AM   #7
cartix's Avatar
This and the new MacAllister DP bodies could be a new Spec class.
Old 01-26-2012, 11:00 AM   #8
YR4Dude's Avatar
Trader Rating: 44 (100%+)
What vid?
YR4Dude is offline   Reply With Quote
Old 01-26-2012, 11:10 AM   #9
YR4Dude's Avatar
2wd, Fwd, Rwd, or 4wd, they should all run in the same class so long as their method of power (motor, battery, and esc) are fixed to the same standard and that they all meet the minimum weight spec.
With brushless and lipo, the DD cars don't have the advantage in drive efficiency as it once did over the gear reduction cars. So long as they both meet the same minimum weight and powered the same, it could be an interesting race to watch.
Old 01-26-2012, 11:16 AM   #10
Xpress's Avatar
Body posts or 4 rollover antennas?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-26-2012, 12:43 PM   #11
redbarton's Avatar
So what if any advantage would this chassis offer over any of the current 1/10 GT pan cars? Better rough track handling due to the conventional 4WD TC front end? Better durability? Simplicity in set up? I can't see a reason for this car unless you are going for something more true to scale for RWD only racing.
redbarton is offline   Reply With Quote
Old 01-26-2012, 01:07 PM   #12
nf_ekt's Avatar
Trader Rating: 113 (100%+)
It's different... but my question is, with the solid axle /RWD, and rubber tires, just how well would this thing actually handle? I'm thinking a handful unless it was silver can on a well prepped surface....
nf_ekt is offline   Reply With Quote
Old 01-26-2012, 02:37 PM   #13
oXYnary's Avatar
Send a message via AIM to oXYnary Send a message via Yahoo to oXYnary
An aluminum chassis?
That thing pushes so hard through those corners.
The all new 'Stealth' is aimed at the budding RC enthusiast wanting the next step up from street bashing fun to club circuit racing without the costs associated with top spec touring cars. The 'Stealth' bridges that gap between budget racing and top flight RC Cars but not at the expense of high specification features.
I have a better suggestion for that budding enthusiast. A real 4wd sedan with near the same tweaks as a normal one but at a fraction of the price (even Tamiya). That can be run on the same tracks in their own class. A Carisma GT14 MkIII.
+ YouTube Video
www.3drcracing.com <<RC Video Game.
Kyosho Mini-Z Buggy, Moto Racer | Losi Micro SCT, 8ight Mini
oXYnary is offline   Reply With Quote
Old 01-26-2012, 02:47 PM   #14
nf_ekt's Avatar
I was thinking a lot of spinning out unless it was on foams. Either way, I would look for something else for a class that appealed to newer drivers, unless they want to sort of get a crash course on pan car and TC sort of at the same time . tt-01 is what I would consider the "gateway" on road machine.
Old 01-26-2012, 06:20 PM   #15
For 'bridging the gap' between budget and top spec the Stealth also costs 150 just for the chassis. For the same money you can pick up a decent budget touring car.
RadshapeRC do make a nice range of sheet alloy replacement parts for other cars. The reason they specialise in sheet metal parts is that the main company Radshape makes parts for the automotive industry in sheet metal, such as the Rolls Royce and Bentley radiator grilles, and the whole chassis for the Morgan Aero 8.
terry.sc is offline   Reply With Quote
