Spintec Battery Manager
#542
This thing ROCKS~~~~
From me and those that got one here in Auckland, New Zealand (its only been 2 weeks) and we are already seeing a difference. The pack is more energised and the charging capacity from the chargers have increase on average 15%.
Thanks Erik and the team at Spintec. Keep up the good work.
#546
Looks like we have some winners!
Rocketron, dyaz21, RobertV, 1fastdude, striderVC, ghostfit, S2, Grazianos, Rob Phillips, kartermdb: please email your address to [email protected] and you will receive a set of stickers.
Mr. Shookie, Hebiki and Lickrim (+Chris), got your address already
Hello FaiLip! Good to hear, let me know if there is anything I can do for you!
Maximum cycle top score so far I have seen is around 270!!
#547
#548
#549
Thanks Erik, your assistance have been greatly appreciated.
Just one question, is there any promotional goods that is available for distributors? I will be ordering some more Batman and would like to get some.
#550
Thanx, email sent, cant wait to put these bad boys on my body and represent
#551
Nice Job!
Eric,
Nice job on the BM. There are a lot of skeptics in my area with the Xray team based here. Lots of real strong drivers.
Anyways, I took the first BM and found it woke up packs that were well short of being race worthy.
Cycled them after each 5 minute run to find some of my 3300 GP packs now have an extra minute of run time when I use my 8x1 in my sedan. The voltage and punch is insane.
As for the numbers, there are a lot of factors that go into how they are obtained. I just use those numbers to reference each pack against each other when they are used the same way. I have a GFX that tells me the packs are awesome.
Spintech them after a run and tray them to zero before a charge.
All the guys in Dallas are seeing this thing.
Thanks.
TEX
Thanks.
TEX
#552
Someone posted a note in here somewhere that the Batman is doesn's work on stick packs. is this true or just some one's opinion?
THX in advance...
THX in advance...
#553
Before I get one of this, can I use this for my stick packs?
Thanks!!!
Thanks!!!
#554
Thanks!!!
Thanks!!!
After the change, it work far better then before (for my Sticks).
In theory it has a reverse voltage protection, that would make safe to be used also with unbalanced packs .. so a generic stick pack.
In practice you have to take care to disconnect the BatMan after no more then 1h after finish the cycle.
e_lm_70
#555
Stick packs
The Spintech BM will cut off at 5.1 volts on a six cell pack regardless if it is a stick or side by side configuration.
After the cutoff point the BM will give the readings of the discharge. At this time it uses so little energy that cell reversal will not occur.
It will not be a problem.
Keep in mind sticks have different resistance ratings than soldered side by side configured packs. (hince the slightly different readings)
The magic is still the same.
TEX
TEX
