Old 08-03-2005, 09:58 PM   #451
highwayman's Avatar
Originally Posted by Roger
I'll usually batman my practice and race packs after every 3 runs. I'll charge them up completely; and discharge them.
Thanks Hebiki
hmmm interesting... this way you get consistent numbers for each pack...
highwayman is offline   Reply With Quote
Old 08-03-2005, 10:41 PM   #452
Still Bill's Avatar
I am immediately Bat Manning all of my partially discharged packs after every use...Good/Bad?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-03-2005, 11:03 PM   #453
jamescam's Avatar
R/C Tech Charter Subscriber
Can someone compare using a tray discharger (like the Integy Zero-Thirty) to this? I understand this will give me more data but will it do a better job conditioning my packs? Thank you.
jamescam is offline   Reply With Quote
Old 08-03-2005, 11:29 PM   #454
Send a message via AIM to micros_rock
What the Spintec does is totally different from a tray. The tray will equalize the cells to a certain voltage or just down to zero so that they are all at the same level when you charge it back up. The Spintec decrystallizes your cells through the pulse-discharging, so it's like maintenance-zapping your cells (without the risk of blowing them, lol)
For best performance/conditioning, you would use the Spintec then put the batteries on the tray.
micros_rock is offline   Reply With Quote
Old 08-04-2005, 09:07 AM   #455
Hello all!
Yellow15, we are at the moment testing the prototypes of a 4 cell Battery Manager. Final version is still not known, but yes it will be for 4, 6 and 7 cell packs. It will also have some additional features, but for now obvious reasons I can not tell yet. Not sure yet when it will be available, expect early next year.
micros_rock, sure 50 amps no problem
Probably in a few years don't be surprised that will be the new standard though...
lotus1, you're right about changing connectors. Readings may be different to others, so comparing is not really possible. But your own readings might be more consisting if the connection is better. There is no risk of damaging the unit.
PomAbroad, to our experience you will gain voltage AND runtime. There will be definitely no loss of runtime.
Itchy, hope your chassis still works
Patenting something like this is difficult and expensive unfortunately. The only thing we can do is stay ahead by innovation, quality products and excellent customer service.
beer_drinker and litespeed_dom, the 'other' unit is not similar to the Spintec device. We have not given other companies access to our technology, so I do not know if it will function the same way.
Do you choose for innovation or imitation... that's the question
Erik Jonk is offline   Reply With Quote
Old 08-04-2005, 10:59 AM   #456
Trader Rating: 21 (100%+)
Default Erik
Thanks.For me I think my own consistent readings are more important.Ithink I can always "compare" by using the improvement differences that many post.Tahnks again,Mario.
lotus1 is offline   Reply With Quote
Old 08-04-2005, 11:13 AM   #457
Trader Rating: 16 (100%+)
So far...after cycling the batteries about 2 time.....each packs are average 2-300 mah more charge then before........and 1 of the matched pack, I ended up having a 3986 mah charge from my Reedy charger reading (on a 3300 mah packs almost 1.5 years old).......that was happened 4:15am, and I am not sure I read that correctly, but I did read that several times........
I know the spintec does works.........I just need the real race feedback (not just the cycling process), Sunday seems like years away...
P.S.......all the SPINTEC data reading after discharging are average 3700-4100mah, 380-420s, IR 30-50, on my almost 2 years old GP 3300 matched cells, sounds a little bit too good, so I don't really concern about how accurate of those #, just wrote them down as reference.....I only trust the final charged reading (MAH) on the charger...
Old 08-04-2005, 07:39 PM   #458
Hebiki's Avatar
Trader Rating: 26 (100%+)
try it at the track. you'll feel the difference is sunday here yet?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-04-2005, 07:42 PM   #459
Hebiki's Avatar
GOOD just do it consistently. that way you can compare your data.
Hebiki Design Works
Old 08-04-2005, 07:52 PM   #460
RichChang's Avatar
I'll go for innovation. I'm looking forward to the new model that does 4, 6, and 7 cells.
-Rich
RichChang is offline   Reply With Quote
Old 08-04-2005, 08:02 PM   #461
Rob Phillips's Avatar
I knew it wouldn't be long before we'd see a clone
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-05-2005, 12:46 AM   #462
beer_drinker's Avatar
Eric, its bad luck that you couldn't get this patented, but at least everyone who ever talks about pulse dischargers will think 'Spintec'
beer_drinker is offline   Reply With Quote
Old 08-05-2005, 07:21 AM   #463
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Erik,
Just please patent the ICC before Trinity and Duratraxx take advatage of your design and innovation.....I think everyone who buys one of the Dyno junk...will realize that the originator of the had it done right to begin with....Plus Trinity also made enough changes that I think they could have gotten it through the lawyers and not been copyright infringing anyway....
Funny how all you have to do is change like three things and it doesn;t fringe...LOL....
I am more worried that Trinity will copyright it and try to force you out of the market....And well know they have the power...
SO with the ICC make it impossible to copy...get the whole thing including the software patented...it will be worth it...
Just my two pennies....I just don't want to see them push you out....
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 08-05-2005, 07:31 AM   #464
BATMAN is only one......... SPINTEC!!!!!!!!
harris is offline   Reply With Quote
Old 08-05-2005, 07:33 AM   #465
I haven't bout one yet, but the Bat Man is on the list. Soon....very soon.
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
FS SPINTEC BATTERY MANAGER kvrc R/C Items: For Sale/Trade 3 10-05-2007 02:22 PM
Spintec Battery Manager Kletke R/C Items: For Sale/Trade 18 11-14-2006 08:54 AM
Spintec Battery Manager olhipster1 R/C Items: For Sale/Trade 3 10-29-2006 05:44 PM
SPINTEC battery manager wikedgmc R/C Items: For Sale/Trade 3 02-22-2006 09:19 PM
