Spintec Battery Manager >
Old 01-10-2005, 07:00 AM
  #31
Eirik's Avatar
Got my discharger the other day from our distributer and have tested a litle bit....
I have only tested with old, poor practice batteries.
I got 200-300mah more into the pack during charging and on the track I had more power during the whole run. Especially at the end where I before was just cruising the last minute I had great power.... Almost like when the packs where new!
This is just great, bringing old batteries back to life!!
Eirik is offline
Old 01-12-2005, 01:50 AM
  #32
Spintec products now coming to Malta too
Thanks Erik Jonk
dhiracing.com is offline
Old 01-13-2005, 01:04 PM
  #33
Good to hear everybody is happy
See some of you in Denmark at the DHI race then!
Erik Jonk is offline
Old 01-17-2005, 06:40 AM
  #34
Just got back from the DHI race, it was some very impressive racing!
The Battery Manager also showed its capabilities again as many racers were using it: A-finalists Andy Moore and Sakke Ahoniemi, as well as Todd Hodge, Simo Ahoniemi, Ben Cosgrove, David Spashett and many others!
Old 01-28-2005, 11:58 AM
  #35
Hello Erik,
Have you got info about the ICC ?
This charger charge a 7,2v battery cell by cell or simply 6 single cells (6x1,2v) like a "turbo matcher" ?
I use the BATMAN, it's great !! My old 2000sanyo are alive !!!
Thx from france
Bastien
Bastos is offline
Old 01-28-2005, 12:42 PM
  #36
berger's Avatar
So does this have a fixed cut off of 0.85V per cell or is it adjustable?
berger is offline
Old 01-28-2005, 01:38 PM
  #37
Yes fixed 0,85v
Bastos is offline
Old 01-28-2005, 05:49 PM
  #38
SalvadoriRacing's Avatar
don't know why some guys are so worried of lower cutoff settings.......
at a higher load, 0.05v or even 0.1v mean nothing but 2 or 3 seconds....it would really matter at lower amps.......
but definetly doesn't hurt any pack when discharging at 20amps or more......
SalvadoriRacing is offline
Old 01-29-2005, 02:37 AM
  #39
Hello Bastien,
Yes, the I.C.C. will charge a 7.2V pack (6 cells soldered in series). Each cell has its own delta-peak and temperature cut-off system.
Old 01-29-2005, 09:35 AM
  #40
Hi Erik,
Just one more indication concerning the ICC charger : does it effectively cut the charge current for each cell or just monitoring each cells ?
I mean for example you cut the charge current on cell #3 of the pack while others cells still charging ? If yes, does it mean that you trully have 6 individuals charger (or act exactly like this) ?
What is the power supply ? AC ou 12V DC ?
Thank you for answering all my questions ;-)
buzzbusy is offline
Old 01-30-2005, 06:20 AM
  #41
Hi buzzbusy,
Yes, it cuts the current for each cell individually. So for example, cells #1, 2, 4, 6 could still be charging while #3 and 5 are already cut off (no current).
It is exactly like having 6 individual chargers, although the technology behind it is a bit more complex than just this.
It will work on any regular 12V DC power supply that can deliver the current that you want to charge at (I suggest a minimum of 6 amps power supply).
Old 01-30-2005, 07:35 AM
  #42
Shop Owner
nnick's Avatar
It sounds very promising!
One suggestion thoughm make a new thread for the ICC
Also, what will be (an estimation will be fine) it's price and when its due?
Nick
nnick is offline
Old 01-30-2005, 08:43 AM
  #43
Mum.......
For the BatMan, everyone did study basic electronic show knew that the term "Power". Power is the equal to Current x Time. So, for a linear discharger, for example, discharge at 35amp for 10 sec, the power is 350W. For the BatMan, the power may only be 35 x 5 = 175W. This is the mistake. When we talk power, we always talk Average power, not instanteous power. I can make a discharger which can discharge at 100Amp for 0.01sec and rest for 10sec, am I right ?
Also, the so called "Cool-flex", in my knowledge, it is just a PWM controller discharge......nothing special !!
BTW, I.C.C. is very interesting......I just want to know will it take the same amount of time to charge a pack of 6 cells with the ordinally charger.
Maxchow is offline
Old 01-30-2005, 10:18 AM
  #44
Originally posted by Erik Jonk
Hi buzzbusy,
But the time of charge could be longer than original "charge style" ? no ?
salut
Bastos is offline
Old 01-30-2005, 10:49 AM
  #45
discharger look justlike my buddys team kinetics prodis from yaers ago? heatsink size to small for 35A? pulse discharge?
ProMaX is offline
