Old 05-08-2005, 01:48 PM   #211
LeoChan's Avatar
Send a message via ICQ to LeoChan
Why discharge need long time ?
LeoChan is offline   Reply With Quote
Old 05-08-2005, 02:37 PM   #212
Because of the CoolFlex it doesn't discharge at 30A all the time. This would make your batteries hot and you don't want that.
It discharges at 30A and then let's your battery cool down again. I don't know the exact number but it discharges for example only 10% of the time, the other 90% of the time is to keep the battery (and the BatMan) cool and make acurate mesurements.
Let's assume it discharges 10% of the time. If your final discharge time is 400 seconds, your stopwatch would say 4000 seconds.
MBreve is offline   Reply With Quote
Old 05-08-2005, 05:18 PM   #213
well you just answered the question i was going to ask, i noticed that the runtime (in seconds) was way off, but your explaintion makes sense, thanks.
Turtlemaster is offline   Reply With Quote
Old 05-09-2005, 01:40 AM   #214
highwayman's Avatar
Default Re: the numbers are in!
Originally posted by Hebiki
discharged three of my packs after racing tonight.
here's the first run (the batteries sat awhile..so im sure the numbers are off)
pack1/pack2/pack3
IR: 44/70/54
Voltage: 6.91/6.28/6.34
after racing tonight.. i discharged them all. batteries have been sitting around 2-3 hours since i got done racing (first set of numbers, the batteries sat around for days)
pack1/pack2/pack3
IR: 34/33.5/44
Voltage: 7.22/7.22/6.97
would this prove that the 2nd charge is indeed stronger than the 1st? thanks -jason
highwayman is offline   Reply With Quote
Old 05-09-2005, 11:39 AM   #215
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Re: the numbers are in!
Originally posted by Erik Jonk
Hebiki, I suggest not to increase the wire length. By doing this you will lose accuracy, the device is callibrated for this length of wire. 35 amps is a lot, and the voltage drop across the wires is in the equation. If you still decide to do it, increasing the wire length without opening the unit is fine. I suggest remove the alligator clips and solder on some longer wires. Cover it nicely with shrink wrap. Try not to increase it by more than 10 cm's. But remember, measurement readings could be changed after that.
Erik
nah.. i wont lengthen the wires. too lazy. plus it'll change the readings like you said. my question for you is... are there any negative effects on the spintec if we have it sitting on top of a small fan while its discharging?
i raced those packs for the first time yesterday...and i couldnt feel the difference in stock (track was long and flowing) BUT.... my car had a lot more rip in 19T. ill have a third set of numbers for some of my packs. ill post when i get home. i noticed one pack dropped 10 in the IR dept, each time i discharged it on the spintec
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-09-2005, 12:59 PM   #216
Alex C's Avatar
Trader Rating: 50 (100%+)
Default Equalizing batteries
Hi Erik,
Question, should I still equalize my batteries prior to charging, or just run the Battery Manager then charge.
Just trying to justify if traying a battery really makes a difference.
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 05-09-2005, 01:19 PM   #217
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i know i aint Erik but i think trays that you can't change the voltage on are pointless, or any that aint below 0.7v.
i use a smart tray at 0.6 and still some lights go out with seconds, spintec claim the discharger goes down to 0.85, i know for a fact it takes some down to less then 0.7.
raving-monkey is offline   Reply With Quote
Old 05-09-2005, 04:42 PM   #218
Does anyone know where I can order one from. I emailed rcmodel-hk to see is they actually had them in stock but I haven't got a reply from them. I tried RcSynergy as well but he said that he was out of them for the next couple weeks. I know Horizon is going to get them but I am don't want to have to wait that long.
dway100 is offline   Reply With Quote
Old 05-09-2005, 04:52 PM   #219
PitCrew's Avatar
There is NO WAY this device or any other device that discharges the entire pack at once can cut-off at a per-cell voltage.
I am sure if it says it cuts of at .85 volts, the unit is calibrated to cut-off at 5.1 volts. Therefore, you could have 5 good cells going and one thats completly tanked, and the discharger would still keep discharging.....
This is ultimatly why a discharge tray is the only way to get all your cells to an even point. Besides dead shorting, but you need to take down a whole pack very slowly if you don't have a tray, and you want to dead short. Otherwise, you can be damaging the cells that have allready gone dead prior to cut-off.
PitCrew is offline   Reply With Quote
Old 05-09-2005, 05:52 PM   #220
tboned_2002's Avatar
Dway- I purchased yesterday. So I will post when i get it.
tboned_2002 is offline   Reply With Quote
Old 05-09-2005, 08:25 PM   #221
Where did you order from? I would like to get one on order.
Old 05-09-2005, 09:38 PM   #222
Hebiki's Avatar
Talking Erik...your famous
Erik
posted a product review of the Spintec Battery Manager on the TAOB Racing website. check it out.
http://www.taobracing.net/index.shtml
here's a direct link to the review:
http://www.taobracing.net/review_spintec.shtml
- Chris
Hebiki Design Works
Old 05-09-2005, 09:54 PM   #223
Hebiki
Where did you order yours from?
Old 05-09-2005, 09:58 PM   #224
LeoChan's Avatar
I'm yesterday go to RC MODEL see instock
Old 05-09-2005, 10:07 PM   #225
LeoChan's Avatar
If you order need use this e-Mail : [email protected]
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
FS SPINTEC BATTERY MANAGER kvrc R/C Items: For Sale/Trade 3 10-05-2007 02:22 PM
Spintec Battery Manager Kletke R/C Items: For Sale/Trade 18 11-14-2006 08:54 AM
Spintec Battery Manager olhipster1 R/C Items: For Sale/Trade 3 10-29-2006 05:44 PM
SPINTEC battery manager wikedgmc R/C Items: For Sale/Trade 3 02-22-2006 09:19 PM
