Old 01-14-2005, 03:58 PM   #31
"I find it very difficult to position the tip of the bit on the tiny gap exactly between the comm segments. It's very easy for the bit to get snagged on a segment as you crank out the bit. "
"Line the bit up with one of the comm slots and move the bit out past the top of the comm"
i'm not understanding this part of the process?
kh15 is offline   Reply With Quote
Old 01-14-2005, 04:18 PM   #32
Jack Smash's Avatar
Trader Rating: 29 (100%+)
It will probably make sense after you get everything set-up in front of you.
You cut from right to left. When you get all the way over to the left next to the tabs on the armature, stop the lathe motor, rotate the armature with you hand until the tip of the bit lines up with one of the slots between the comm segments, and move the bit all the way back over to the right. Then turn on lathe motor, reblack the comm with your sharpie, turn the bit in one notch on the dial, and then cut again from right to left.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-14-2005, 10:49 PM   #33
ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhh okay so i just line it up with the notch so i can re-set the bit with out pulling the bit away from the comm!!!!! yes i get it, so how many passes should i make to get a perfect comm? and how many times can you cut a comm before its just not worth it anymore
Old 01-15-2005, 12:10 AM   #34
kh,
You'll know when you've made enough cuts when all the sharpie is gone,it may take a few cuts but just keep marking the com with your sharpie until the markings are all gone in one single pass,actually I use a dry erase marker but a sharpie pen works just as well.One notch on your lathe should equal 1/1000's.Go here and it will explain and show you in detail about cutting your com. http://www.motortuningsecrets.com/
Hyper1 is offline   Reply With Quote
Old 01-15-2005, 01:13 AM   #35
well i belive thats it for the questions for me! thank god i know you all saying lol but i will let you know how my first cut comes out! thaanks! \m/
Old 01-17-2005, 02:39 AM   #36
this is probley gonna sound like a really retarted question but what sound should the lathe make when im actually cutting? i just figure if i know what sound to listen for and i hear something diffrent i will know right away
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 04:56 PM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 12:53 PM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
Integy Lathe and Trinity Real Time 2 Discharger For Sale Bobby Z R/C Items: For Sale/Trade 3 03-15-2004 11:24 PM
run time VS tweak time bigbutstupid Electric On-Road 7 06-16-2002 04:40 PM
