Old 01-02-2005, 09:58 AM   #1
Secret_weapon's Avatar
Post Best Power Supply
hi guyz
what is the best type of power supply that can be used 4 chargers. And from where i can get it and what's the price .
thank you
Secret_weapon is offline   Reply With Quote
Old 01-02-2005, 10:04 AM   #2
Matt Howard's Avatar
I've used the duracomm powersupplies for the past couple of years and they're really good and nice and thin. You can find them at http://www.speedworldraceway.com/Pag...ID=201&Search=
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-02-2005, 10:04 AM   #3
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Best Power Supply
Originally posted by Secret_weapon
hi guyz
thank you
If you look at the top of the page you can use the search feature . but check this thread outhttp://rctech.net/forum/showthread.php?s=&threadid=58077
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 01-02-2005, 10:24 AM   #4
I have used both the Rivergate and the Duracomm power-supplies ... no complaints on either - but the Duracomm is a little smaller in physical size.
duckman996 is offline   Reply With Quote
Old 01-02-2005, 10:31 AM   #5
razzo's Avatar
Send a message via Yahoo to razzo
check this PS out:
http://www.shopatron.com/index/166.0.4839.0.0.0.0
KO resells it, it can be found at Ham radio places for little less (around $160)
32 amp for $160. Lot cheaper then other 'RC' Power supplies.
razzo is offline   Reply With Quote
Old 01-02-2005, 10:46 AM   #6
Jay Boyd's Avatar
Here's what I use. http://www.bkprecision.com/showprodu...Power%20Supply I've seen it online for about $250.
Jay Boyd is offline   Reply With Quote
Old 01-02-2005, 12:42 PM   #7
Post
Thank you guys
you were very helpfull
Old 01-02-2005, 04:02 PM   #8
Regional Moderator
kumpol's Avatar
Samlex SEC 1223
If you use 5.5 Amp for each charger, this may be a good choice!!!
--> 23 AMPS Continuous! (25A intermittent)
Weight: only 3 pounds
Input voltage 100-130 OR 200-260 VAC 50/60 Hz.
(internal jumper selectable)
$99
http://www.radiodan.com/misc/samlex1223.htm
kumpol is offline   Reply With Quote
Old 01-02-2005, 04:23 PM   #9
Just make one from a PC 500 watt psu, you will get 20-30A for less than $60
Galifrey is offline   Reply With Quote
Old 01-02-2005, 04:30 PM   #10
i have used the samlex running three chargers all day with no problems. charging at 5 amps. i dont knoe if i would try four. you would be running at max. rating.
the rivergate 30 amp may be a better choice.
www.rivergatedist.com you can order direct. its cheaper
baih is offline   Reply With Quote
Old 01-03-2005, 11:30 PM   #11
eforer's Avatar
Send a message via AIM to eforer
it won't run four chargers but for the price you can easily buy two and run 6 chargers if your were so inclined. The pyramid psv-200 is a 20 amp switching power supply it is very small (7"X7"X2") and very light at 3lbs and is stackable with no top vents. The best part is that its $55 pretty much every where.
eforer is offline   Reply With Quote
Old 01-04-2005, 12:29 AM   #12
Hebiki's Avatar
Trader Rating: 26 (100%+)
i got a 28 amp power supply for sale from Integy/SHE. i used it before to power two pulsars, motor break in, pitbull and GFX at a race with no problems. (all four chargers going at once charging at 6amps) while running my lathe at 5volts. check my signature.
Link: http://www.rctech.net/forum/showthre...threadid=58783
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-04-2005, 04:36 AM   #13
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally posted by razzo
check this PS out:
And alot cleaner output. Today chargers required a very clean power supply for their tiny Microprocessor.
32 Amp max output terminal is on the back.
2 5 Amp terminals on the front
1 10 Amp terminal on the front.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 01-04-2005, 05:05 AM   #14
Thumbs up
I will just make up my mind, i have really good choices.
Thanks guyz
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
turning pc power supply into a rc power supply andy_666 Electric On-Road 20 01-16-2006 05:20 PM
SEC Power Supply vs. Hobbico Power Supply? F1Junkie Electric On-Road 1 06-05-2004 08:52 AM
