Old 01-06-2005, 02:59 PM   #31
you will need to change the pinion (smaller) but not the spur.
flysti is offline   Reply With Quote
Old 01-06-2005, 03:05 PM   #32
R/C Tech Charter Subscriber
Depends on what you are running and what pinions you have. For some it might be easier to change the spur to a bigger one and use all the pinions you have. You don't have to change just the pinion.
NismoSkyline17 is offline   Reply With Quote
Old 01-06-2005, 03:15 PM   #33
i was refuring to the stock spur 93teeth.
so the changes i made was to just go to smaller pinions. all you have to do is goto gearchart.com & get the 1.77 ratio chart
Old 01-06-2005, 03:57 PM   #34
NVisible's Avatar
just trying to plan ahead and make sure i have everything im going to need for my new xray. I figured a 23T pinion would work in Stock, but i thought i should double check with people actually running the car.
thanks guys
NVisible is offline   Reply With Quote
Old 01-06-2005, 05:18 PM   #35
You do have to change your spur/pinion gear combo to adjust for the different internal gear ratio.
ok let's say i have two exact cars with the same set up, same motor and the only exception of one having the lower internal ratio pulley set (1.77), their final ratio got to be equally the same as well (remember same # of turns in motor) top speed in theory should also be the same as but the one running the lower internal ratio should reach top speed first, if that's what it does i certainly going to get!
cheer
Omar R.
Quiet is offline   Reply With Quote
Old 01-07-2005, 12:02 AM   #36
cheer
Omar R.
Exactly.
Xray T1FK '04' leigh taylor Australian Racing 2 12-21-2005 05:17 AM
xray t1fk mickrcarver R/C Items: For Sale/Trade 1 11-02-2005 05:08 PM
Xray T1FK skip hall R/C Items: Wanted to Buy 3 01-12-2005 02:38 PM
fs: XRay T1FK XCrash R/C Items: For Sale/Trade 4 11-19-2004 02:03 PM
Looking For Xray T1fk pete68 R/C Items: Wanted to Buy 1 10-29-2004 04:33 PM
