Old 01-18-2012, 08:49 PM   #1
Default Is their a reset button on the vxl 3s to put it back to factory settings
302DZ is offline   Reply With Quote
Old 01-18-2012, 09:24 PM   #2
SourDieselX's Avatar
If you go on Traxxas website and look up your ESC it'll tell you. I believe it is hold the power button down until it goes green and then to red, when it's red, release the button, it'll blink red twice, then you pull the throttle until it blinks red again, then you push forward on the brake until it turns green, after that, you should be good to go.
---Sponsor: Remote Control Hobbies---
http://www.facebook.com/pages/Remote-Control-Hobbies/156985487744758
Go big or go home!!
SourDieselX is offline   Reply With Quote
Old 01-18-2012, 09:45 PM   #3
sec1083's Avatar
Trader Rating: 29 (100%+)
Default vxl settings
Also to set the power and reverse settings you need to press and hold the power button from the esc being off untill red light blinks once and release that should be your full power forward and reverse this is profile 1 continue to hold for two red blinks and release this will be profile 2 race mode full forward full brakes no reverse continue to hold for three blinks and release this will be profile 3 witch is training mode 50% forward 50% reverse. Hope this helps also
sec1083 is offline   Reply With Quote
Old 01-18-2012, 10:27 PM   #4
Yeah I tried recalibrating it but when you turn left then the car move and right you turn it moves but when you press the throttle the car does not move how do I make it listen to the throttle
Old 01-18-2012, 11:13 PM   #5
Sounds like your throttle and steering are plug into the wrong channels in the receiver. Channel 1 is steering and channel 2 is throttle. Fix the plugs and recalibrate the esc.
Sydewynder is offline   Reply With Quote
