Old 01-01-2005, 09:18 PM   #1
Send a message via AIM to nuttcase21
Default need help building a discharger
i'm trying to build my own discharger, but i need a little help. i've got a bunch of 1157 automotive bulbes, but i need to know how to arrange them. should they be soldered in parallel or in series? and approx. how many bulbs will i need? thanx in advance guys.
nuttcase21 is offline   Reply With Quote
Old 01-01-2005, 09:26 PM   #2
RC Professor's Avatar
The bulbs on a discharger should be soldered in parallel- connect all the positives together and all the negatives together. I think the 1157 automotive bulbs draw about 2 amps each, so, for example, if you want a 20A discharger, you will need 10 bulbs.
Hope this helps.
RC Professor is offline   Reply With Quote
Old 01-01-2005, 10:09 PM   #3
FlyinGT's Avatar
Send a message via AIM to FlyinGT Send a message via Yahoo to FlyinGT
also when making the discharge ...add a relay onto the discharger, an put resisitor on it so it will cut off at 5.4v
using a voltmeter an testing which one will let it cut off at 5.4v
so u don't have to monitor the pack ... as it will cut off b4 anything bad can happen to ur cells !!
FlyinGT is offline   Reply With Quote
Old 01-01-2005, 10:16 PM   #4
i've only got 4 cell packs to discharge, so my cut off voltage should be 3.6 volts correct? or .9 volts per cell. how do i go about putting a resistor on a standard auto relay to get it to cut off automatically?
what's the diff btwn 0-30 discharger & novak smart discharger straightaway Electric On-Road 9 09-12-2006 07:15 PM
Wanted: Discharger and/or Discharger building info oMONSTERo R/C Items: Wanted to Buy 7 06-20-2006 06:24 AM
Building a discharger? aus jd 2703 Electric On-Road 5 06-04-2006 10:23 PM
need help with building a discharger maximebeauvais Electric On-Road 0 12-08-2005 12:43 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 05:23 AM
