Old 01-18-2012, 02:41 PM   #1
theatriks's Avatar
Default What hudy set up station to get
hey guys im looking to get a hudy set up station but am kinda confused in which to get as there seems to be 2 of them ...first is the hudy 108255...and second is the hudy..108256 now the only difference i can see is the set up station comes with a board but no set up wheels and the other set seems to come with set up wheels and no board ...whats everyones opinion on which to go with ...thanks.
theatriks is offline   Reply With Quote
Old 01-18-2012, 02:58 PM   #2
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
id go with # 108255 and get s set of these http://www.speedtechrc.com/store/ebp...id=384&id=9226
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 01-18-2012, 03:02 PM   #3
theatriks's Avatar
those look pretty sick but idk about mounting it to a set up station without wheel nuts
Old 01-18-2012, 03:37 PM   #4
Lessen's Avatar
Send a message via MSN to Lessen
I have the second kit your posted (108256) and have been extremely pleased with it. If you opt for the less expensive kit you swap the nylon case for an aluminum one and you get a setup board w/sheet. However, you do not get setup wheels, balance pins, quick camber gauge and a second (fine) droop gauge.
I like the nylon case more because there are places to put more items. I have added the Hudy wheel balancing pieces to my setup garage and the parts fit nicely
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 01-18-2012, 03:55 PM   #5
JasonC's Avatar
they Thread on the Axles just like a Wheel nut..
Old 02-29-2012, 11:15 AM   #6
So OP which setup system did you get? I'm kinda in same position
zzztech is offline   Reply With Quote
Old 03-22-2012, 06:33 AM   #7
theatriks's Avatar
ok so im confused as to what u get with the hudy set up system #108256 ....stormer hobbies shows this system without quick camber guages and other sites show that it comes with the quick camber guages sooooo which is it?
Old 03-22-2012, 07:08 AM   #8
Lessen's Avatar
108256 DOES come with the quick camber gauge
Old 03-22-2012, 09:50 AM   #9
Easiest to trust the official Hudy website: ht tp://www .hudy.net/xhudy/products/prodpart.php?prod_id=475&kategoria=475 (remove spaces, I'm not allowed to post links yet)
halldor is offline   Reply With Quote
Old 03-22-2012, 10:10 AM   #10
Odin544's Avatar
Trader Rating: 93 (100%+)
I've got the Hudy 108256. It works great. You don't need a hudy setup board and sticker. You just need a good flat surface. And maybe it's just me but I don't see a use for setup wheels either. Not if you have a setup station...
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-22-2012, 10:18 AM   #11
Hi
I ended up with 108256
Its newer and the case is more convenient to carry than an aluminium one plus its got the quick setup wheels
Old 03-22-2012, 10:35 AM   #12
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Who had them in stock? Seems everyone is out of the Hudy setup station.
Dan is offline   Reply With Quote
Old 03-22-2012, 11:10 AM   #13
Odin544's Avatar
In stock at A-main
TriCitiesRC.com
Old 03-22-2012, 11:11 AM   #14
Trader Rating: 38 (100%+)
I got mine from A Main Hobbies a couple weeks ago. They are hard to find. Seems RC America has trouble getting them. Everytime I asked RC America directly I was told "a couple weeks".
EDIT: Looks like they are in stock:
http://www.amainhobbies.com/product_...10-Touring-Car
If you search the web you should be able to find a $25 off coupon.
or8ital is offline   Reply With Quote
Old 03-22-2012, 11:19 AM   #15
theatriks's Avatar
ok cool where do u find this coupon and did it come with the quick camber guage
Hudy set up station losi_racer Nitro Off-Road 61 12-04-2011 10:02 PM
Are pros using the Hudy Set Up Station? NR Electric On-Road 28 11-07-2011 06:00 PM
Hudy set-up Station #108255 xrcbuggy Nitro On-Road 29 04-23-2011 02:27 AM
