XRAY T3 TRF416 417 TA05 TA06 TC6.1 & Tamiya MINI owners "BETA TESTING PROJECT"
#196
Anybody using the mini axles from R1? How deep do the pins sit in your aluminium hexes? I have two sets of axles that the axle pin does not sit deep enough into the hexes I have tried. I thought that I had explained this well enough to Steve, but I don't think that he is understanding what I am telling him in the e-mails or pics I have sent him.
We are beta testing this products to weed out issues like this before they are sold to the public.All the feedback's from the beta testers are reviewed & addressed as necessary.if its something we can correct asap, we will. If not we will schedule the next prototype as soon as we have machine time available.
We clearly stated that we would like discussions on our beta testing done by email or Pm's for a reason.If you don't understand why we're doing that, feel free to let us know & we will give you a full refund as soon as possible. We respect you opinion, we just did not plan to do a publicly announced beta testing.
Steve
R1wurks.com
#197
contact info added on signature.
#198
update for tc6 dcj's. here are some pics of the completed dcj kit including the prototype c hubs. We decided to go this route since we noticed serious draw backs from modifying the factory c hubs.The current prototype uses a bigger bearing (5x10x3) improving bearing reliability.
Trf416 417 & t3 dcjs work just fine without mods & using factory bearing
#199
#200
#201
#203
One really great thing ive found with running them in my mini, is purely easier maintenance.
The design doesn't allow dirt really to get stuck in the joint, not like the standard cvd, they go crunchy pretty quick once dirt gets in.
Also they have very easy access to check the pin and grub screw.
#205
sorry for the late reply, been busy working on new products.
we made a big change on our dcj's, they will now come with a retainer clip to hold the pins in place.
DCJ'S will also now feature our proprietary Ceramic Coating.
we opted to add this features for the following.
-improved pin retention (dont have to worry about pins coming loose)
-improved tolerance
-almost zero backlash (improved acceleration,braking & a more direct feel compared to currently available dcj's in the market)
-dry lubrication (can be run without lube)
-ultra low friction (thanks to Ceramic technology)
-improved wear resistance
we could have finished sooner, but we decided to make a better product.
samples should be done by the end of the week.
we are also in the process of testing our new line of motors, that should be available soon.
Steve
-improved tolerance
Steve
#206
sounds good,
Just found out another excellent thing about the mini cvd's.
you can actually remove the cvd without having to unbolt the knuckle from the c-hub, as they just squeeze through the oblong gap.
really saves time, and knowing that i dint have to remove the kingpins on the c-hub/knuckles, i know that while running they aren't going to fall out do to constant wrenching.
#207
i have a T2R pro and would love to test the ECS drive shafts. The stock drive shafts throw the pins after a weekend of hard running. I live in New Jersey and Im planning on racing on asphalt this summer.
#208
-improved tolerance
Steve
-improved tolerance
Steve
#209
I ran with the R1wurks shafts and axles in my T3 at our nationals last weekend and finished 4th.
All I can say is that they are extremely light and durable! I can't wait to try DCJ's!
#210
Hi, I'm from Singapore and won't mind helping you test your products as I've been testing quite alot of other products as well. Test in local races and international as well.
Drop me a mail if you are ok.
[email protected]
I'm racing local Tamiya Asia Cup Qualifing in the M-Chassis Class and FF03 Class. Current Overall placing is 2nd.
[email protected]
