Old 01-01-2005, 12:36 AM   #1
Trader Rating: 60 (100%+)
Default Too Much Heattt
Ok...brand new car batts motor etc etc..Yokomo mr4sd ssg nothing is in a bind its all free and turns fine so i know it isnt that...but my batt lasted maybe...2 minutes and batt and motor got pretty hot. Why? Batts- epic 3000 sport pack charged on integy 16/7 and i did cycle them a few times before i started to use them and the motor is the epic outlaw stock motor. Its geared stock pinion and ring that comes factory from yok i think its like 30/78 or something tell me why the batts die so fast and get so hot
PROMODVETTE is offline   Reply With Quote
Old 01-01-2005, 12:52 AM   #2
hogdaddy77's Avatar
perhaps the batteries false peaked....or something in your motor (bushing) was hung up...
all sorts of things happen once the rubber meets the asphault
hogdaddy77 is offline   Reply With Quote
Old 01-01-2005, 01:10 AM   #3
Matt Howard's Avatar
You are way overgeared, the supplied spur and pinion is for the japanese 8 minute 23T motor class. try a 25 tooth pinion with that spur gear and you should be fine.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-01-2005, 02:49 AM   #4
batts false peaked? how do i correct that? And bushings lockin up...hmmm i got some special oil we use in real racing engines that will help that i will try some! thanks for the gearing info i will try that also!
Old 01-01-2005, 05:40 AM   #5
It's your gearing, trust me. You were geared at 6.1 which is way way too low for a regular stock motor. A ratio around 7.2 is a good place to start
RCTech #361
Old 01-01-2005, 06:00 AM   #6
Sleighty's Avatar
yer its your gearing, everyone gets rid of the 30tooth pinion that comes with the kit as it makes you miles overgeared.
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 01-01-2005, 08:12 AM   #7
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Or maybe that the battery shorted. If it is then it will only last a minute or 2.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-01-2005, 10:45 AM   #8
if the battery shorted it wont make the motor hot..
it is gearing.
MManson is offline   Reply With Quote
Old 01-01-2005, 10:49 AM   #9
Registered User
Yeah it is mostly gearing, if that epic pack is brand new it may take a few more cycles before it's up to full capacity as well. The ones I bought required about 7-8 cycles in the car before they showed their full capacity.
Combine a unready pack with too much gear and you've got a short run.
Desolas is offline   Reply With Quote
Old 01-01-2005, 02:55 PM   #10
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
First gearing.....then FREE IT UP!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-01-2005, 04:00 PM   #11
Default too hott !!
as recomended .. re-gear your car .. !!! let your batt rest over night then re-charge . you shouldnt have any problems .... sounds like a nice car to run ..
Mark Barden .
mb racer is offline   Reply With Quote
