Old 12-30-2004, 07:34 PM   #1
Neil's Avatar
Send a message via MSN to Neil
Default Magma Dyno-Charge
Do any of you guys have one of these chargers? I was wondering what size power supply it would need.
http://www.magmarc.com/pages/catalog/aps.asp
Thanks Neil.
Neil is offline   Reply With Quote
Old 12-30-2004, 08:07 PM   #2
Should have mine early next week Neil. I would have at least a 10A. Really any of the RC PS's should get you taken care of.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 12-31-2004, 12:10 AM   #3
PizzaDude's Avatar
Somehow it seems related to the Trinity and the Much-more unit.
PizzaDude is online now   Reply With Quote
Old 12-31-2004, 01:01 PM   #4
hogdaddy77's Avatar
is this a decent charger?
hogdaddy77 is offline   Reply With Quote
Old 12-31-2004, 03:40 PM   #5
I just got mine!
What can I say from first impressions:
Very easy menu I didn't need the instructions.
5 charge profiles that can be renamed and all adjusted
Saves your dyno runs for review after
Shows charged capacity and real times
Shows Max amp draw at which Volts and RPM
Shows Max RPM at which Amp draw and Volts
Very nice real backlight white lettering on Blue
Nice charge clips for power supply and battery
Comes with Motor stand and Temp prob.
So far so good, the charger for the price is the best in its class.
Related to Trinity and muchmore?
Trinity does'nt charge batteries and niether does the muchmore.
The box is also mint only thing is no foam in the box or the charger to sit in. Very light and nice black case.
Get one if you are looking for a new charger.
Gordie
Chunyee is offline   Reply With Quote
Old 12-31-2004, 07:28 PM   #6
Neil's Avatar
What were you running for a power supply? I think I'm going to get this one its 25 amps for a very good price. http://www.universal-radio.com/catalog/hamps/3747.html
Oh yea how much did you pay for yours?
Old 12-31-2004, 10:12 PM   #7
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
you wil need a power supply rated as high as the maximum amp draw allowed by the charger...
so if it pulls 8 amps for charge u need 8 amps..
but if the motor run feature pulls up to 12 apms, then u need at least 12 amps.. i wuld recomened, at least 3 amps higher then the allowed for the motor run.. this way if it spikes (momentary higher amp draw) then it will be safe..
all the other features on the power supply dont pull enough power to riase amp draw.. there voltage based numbers..
burbs is offline   Reply With Quote
Old 01-02-2005, 05:30 PM   #8
Actually, some of the new chargers uses a technology called PWM which uses power much more efficiently. Say if you're charging a battery (say around 9V when full) less than your power supply voltage (say 13.8V) at 5amps. The charger will actually draw about 4 - 4.5amps.
So if you plan on charging a 7.2V pack at a maximum of 8amps then a power supply of 8 or more amps will be more than enough.
For older technology the charger actually dissapates the excess votlage as heat so it's less efficient. In that case then you would require a power supply with output more than 9-10 amp to charge any pack at 8amps.
I believe the APS Dyno-Charge is one of the newer chargers to use the PWM technology. That's why it's so lightweight and compact and it doesn't require a fan to keep it cool.
I just got mine a yesterday!! It works great and it looks even better!!!
Asurada Sugo is offline   Reply With Quote
Old 01-02-2005, 06:27 PM   #9
Used it all day no heat no fan noise, very small and convenient. no problems , nice carry box no false peaks.. uuummm nothing much to say good charger
Old 01-02-2005, 09:20 PM   #10
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Ya got PM
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-03-2005, 06:42 PM   #11
Neil's Avatar
Does the charger draw alot when its dynoing a motor? Is 25 amps enough for this charger? Guys let me know.
Old 01-05-2005, 03:46 PM   #12
I heard this Dyno charger is designed by a local Canadian racer. If you guys have any question about this charger, you can post your questions in the www.torontorc.com forum.
Raycer is offline   Reply With Quote
Old 01-08-2005, 08:14 PM   #13
Korey Harbke's Avatar
I just purchased one and I think it's awesome. It has a very interesting "pulse" break in, and it comes with a motor stand for dynoing the motors and then a seperate temp probe that you can plug in too. It's sweet. Charges good too, good punch and I got more runtime than my pulsar.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-08-2005, 08:27 PM   #14
Mike Haynes's Avatar
A 25 amp suply will do fine. I run the dyno charge and a turbo off it with no problems.
I personally think its much nicer then the trinity, the ability to charge puts it a big step up. If only it had a nice high discharge capability, that would put it way up in the ranks.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-08-2005, 09:55 PM   #15
You are correct ... this charger was developed by one of the guys that race at this club ... smart guy and a serious racer. I am sure that if you post your questions there, you should be able to get some help.
duckman996 is offline   Reply With Quote
APS 3-in-1 Dyno Charge Rob Phillips Electric On-Road 268 10-17-2009 11:26 AM
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS Dyno-charge Deves R/C Items: For Sale/Trade 9 08-11-2006 07:41 PM
WTB: APS dyno charge v3. Dasupacat1 R/C Items: Wanted to Buy 1 07-01-2006 12:00 PM
