Old 01-11-2012, 10:41 AM   #1
Show871's Avatar
Default How do you manage your lipos for best performance on race day?
What lipo routine results in the best possible performance from your lipo batteries?
Show871 is offline   Reply With Quote
Old 01-11-2012, 10:53 AM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
I am not sure my lipo packs end up with the 'best' performance during race days but here is what I do. I charge my packs at the 1C rate using a Thunder Power TP610c balance charger and I always balance change. My 5000mAh lipos are charged at 5 amps, 2400 lipos at 2.4 amps, etc.
If there is enough time between qualifiers I like to charge at lower amp settings of 1 amp or lower just to ensure both cells are at their highest voltage. I normally see 4.200 or slightly better per cell when charging at the 1 amp (or lower) setting.
SteveM is offline   Reply With Quote
Old 01-11-2012, 11:46 AM   #3
elex300's Avatar
Trader Rating: 102 (100%+)
I just charge them on race day at 1c before the races start. I usually balance mine to 3.89 give or take after I race.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 01-11-2012, 12:21 PM   #4
locked's Avatar
I found that charging at 10A or higher with an end voltage of 8.44 (4.22V/cell) gives a fair bit more rip than when I was charging my batteries before at 5A with an end voltage around 8.39.
My friends have chargers that will charge to around 8.44V, but they can't charge higher than 7A. When I charged their batteries at 12A (2C), they noticed the extra oomph.
I didn't expect it would make any difference, but it does.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-11-2012, 12:51 PM   #5
Trader Rating: 30 (94%+)
I run mod and don't worry about it.
Seriously though, 10A charge, make sure they are balanced, and go.
Rocky8333 is offline   Reply With Quote
Old 01-11-2012, 12:52 PM   #6
I just make sure they're charged and go race.
AreCee is offline   Reply With Quote
Old 01-11-2012, 01:00 PM   #7
Starteur's Avatar
I use a TP610C, I charge with the balancer on first charge of the dayn to practice and after that I use the Competition Car Mode and always get a charge at 8.44 volts. This is the CCM function on the charger.
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 01-11-2012, 02:14 PM   #8
Show871's Avatar
Thanks for the heads up guys. The reason I asked is because I ran a few packs that had been charged for 5 days. I noticed them slower than a fresh raceday charge.
Old 01-11-2012, 02:37 PM   #9
Charging at higher current makes no direct difference to there performance.
You can charge the packs the day before and there will also be no difference in performance.
But lipos do not like the cold and charging at higher current can increase the packs temperature giving better performance, the exact same results can be achieved by charging at a lower current and warming the pack.
On my 30A discharger I always get better numbers when the packs are warmed by either leaving them in the sun for 15-20 minutes and they always perform better on there 2nd and even better on there 3rd cycle for the day.
There was lipo warmers available not sure if they still are but I haven't seen anyone using them in years. I know of people using lipos in very cold climates snow ect when using helis that have had to warm placed them in front of the heater them to stop hitting the voltage cut off on full charged packs.
So to sum up for best performance charge the way you are now and make sure the lipos are not cold.
frozenpod is offline   Reply With Quote
Old 01-11-2012, 03:13 PM   #10
good to see some sanity
My best tip is not to forget batt tape or connectors.
And buy a metal toolbox to store them in for safety.
I have heard that you can safely leave them fully charged (within reason) if you put them in the fridge.
1101 is offline   Reply With Quote
Old 01-11-2012, 03:22 PM   #11
DesertRat's Avatar
The whole "maximizing the battery performance" argument went out with the NiMH pack. As long as your LiPo's have like ten charges on them before hand running more cycles through them wont do a thing, so just charge them up and go. You should think about spending the time you might take to do some weirdness to them on car tuning, practicing, or psyching out the opposition.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
why are we still running sub-c cells?? trackpower Electric On-Road 310 12-27-2007 09:48 PM
