Old 12-28-2004, 07:52 PM   #1
Default CVD's rubbing
Does anyone else have a problem with the rear CVD's rubbing the springs? They rub and I have the car length at the middle position. Is something amiss with my setup? Thanks in advance for any help.
scotwithonly1t is offline   Reply With Quote
Old 12-28-2004, 07:54 PM   #2
Default RE: CVDs Rubbing
Sorry, I thought i was in the TC3 thread.
Old 12-29-2004, 10:02 PM   #3
Shortbus Racer2's Avatar
scotwithonly1t
thats actually something i've seen alot. My TC3 has had the problem. One thing you might want to check is the ride height
or check the shock oil. They may be leaking or just not filled completely. Usually the rubbing won't cause to much of a problem but this might help.
Shortbus Racer2 is offline   Reply With Quote
Old 12-29-2004, 10:18 PM   #4
Also, once you have checked that, you can put some washers in on the top or bottom mounts to move the shock out some.
Rubbing alcohol to clean a body bigdog xxx-s Painting, Designs, Graphics and Photography 3 12-28-2007 10:27 PM
batteries rubbing Hayden Electric On-Road 4 08-01-2006 08:07 AM
Rear Tires for Xray Factory RUBBING! HELP Hypnomagic Electric On-Road 1 11-13-2004 11:03 PM
pipe rubbing on Lexan corvettecrazy Electric Off-Road 11 07-20-2003 12:47 AM
savage.21 header rubbing gunyadown Rookie Zone 0 05-14-2003 05:46 PM
