Old 12-27-2004, 02:23 PM   #1
Default umm...
did i get a good deal for this car it was 251 shipped
http://www.rctech.net/forum/showthre...threadid=58421
yokomo7 is offline   Reply With Quote
Old 12-27-2004, 02:41 PM   #2
Joel Lagace's Avatar
i think u got a good deal.
U got the car for about 40$ less then a new one online. Plus you got a great body painted well with tires and rpm upgraded rods.
I personally raced 2 of these cars over the last 2 years and just loved them! Build your self a fullwidth front bumper and enjoy shaftdrive the way it should be. FAst and easy to work on
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-27-2004, 02:45 PM   #3
Default k
ok thanx alot man
Old 12-27-2004, 02:46 PM   #4
Default um..again
i was told that this type of car gets scratched up real easy running on asphault is thier away u can protect the bottom of chassis besides that tape that makes it all sticky and crap>?
thanx again
cory
Old 12-27-2004, 02:53 PM   #5
UGGGGG i hate running a graphite car on pavement, the SSG will look like poop if u scratch it up cuz the silver is only the outer layer. Perhaps get the CGM comp chassis for outdoor running and save the sexy silver for carpet?
Assoicated used to make a clear sheet sticker for protecting the bottom of chassis, you could get by with coverite(airplane covering)
www.rcottawa.com
Old 12-27-2004, 02:59 PM   #6
Default well....
i am running on inddor track i dont no if it will do alot of damage.
Old 12-27-2004, 03:03 PM   #7
you should be ok but the outer 5mm of the chassis will likely scrape under hard cornering. Even on carpet i get foam pickup on the edges of the chassis
www.rcottawa.com
Old 12-27-2004, 03:08 PM   #8
Default ok
ok thanx for all the help guys i will figure somethin out
Old 12-27-2004, 05:19 PM   #9
Default Re: ok
Associated still makes a clear sheet chassis protector around $8.00. You don't need it for carpet, unless you run over a board.
pops is offline   Reply With Quote
Old 12-27-2004, 06:16 PM   #10
You can buy self adhesive mylar window film used for opaquing bathroom windows which is incredibly tough for use under a carbon chassis...
Local DIY store 10 bucks a square foot
Galifrey is offline   Reply With Quote
