Old 12-27-2004, 02:07 AM   #1
Team-RTR's Avatar
Default Eagle CDC questions
hi guys, i have a eagle CDC V6B, and i was wondering what the cutoff rate for the discharge function was?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 12-27-2004, 02:36 AM   #2
0.8V
Bandini is offline   Reply With Quote
Old 12-27-2004, 02:39 AM   #3
Team-RTR's Avatar
this should suffice for GP3300s or is that a little to low. also, do you reccomend that i cycle my packs when i first get them? if so at what amp rating and what discgarge rating?
thanks!
Old 12-27-2004, 02:48 AM   #4
I use a CDC and set the discharge to 1 cell higher in the pack...(7 cells for a 6 cell pack)
That way my SP tray gets some work to do in equalising the cells...
Going to 0.9-0.8v percell makes the tray redundant...
Galifrey is offline   Reply With Quote
Old 12-27-2004, 07:55 AM   #5
lee82gx's Avatar
cycling a new pack is unnecessary. simply drive it on the car.
There is not much difference between 0.8V cut-off and 0.9V. The difference is about 1/2 seconds only @20A.
usually even if it goes to 0.8V with the CDC, i can still use any tray and it'll still light up.
lee82gx is offline   Reply With Quote
Old 12-27-2004, 08:55 AM   #6
That may work for you, but my tray cuts at 0.9 so discharging to 0.8 kills the equalisation process... the lighting up is purely where the cells have "come back up" the voltage recovers slightly after the discharge has completed, but the cells are not then equalised..
Old 12-27-2004, 02:30 PM   #7
Cole Trickle's Avatar
I wont recommend this, because the CDC uses the cell number to calculate a safe voltage range to work within... Thus you're fooling around with the safety circuits... You're talking a risk with this.
It sounds like you are using a tray with a high drain, correct? Which one are you using?
I'm discharging 6 cells pack at 20 amps, and my equalizer do a good job afterwards. My equalizer discharges at one amp.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-27-2004, 05:10 PM   #8
Hi Cole
I am using the eagle racing sp equaliser/conditioner...
The UK distributor who is "very" well thought of in the UK car racing field told me to do this as thats what all the team drivers do, including his son...
Remember I am only discharging at the increased setting and the voltage is set at 0.8v per cell on discharge...
Therefore the CDC cuts at 7x0.8v/6=0.93v volt per cell... the SP tray cuts that to 0.9v per cell for equalisation and 0.6v per cell for conditioning...
As long as I dont hit charge on that setting I shouldnt have an issue..
Gah, now I've cursed myself...
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
jp eagle 12 TL SOLOARTIST 702 Onroad Nitro Engine Zone 15 01-02-2008 12:39 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 03:39 PM
Eagle 3 VerOn_Pat Electric On-Road 0 11-27-2004 11:50 PM
