Old 01-05-2012, 12:35 PM   #1
Default HPI E10
I'm new to the r/c world but just bought and hpi E10 monster energy drift which I have just made a few changes to. Replaced 27t motor with firebolt 15t. 5000mah 6cell batt., and ditched the drift tires for sport tires. also replaced rims and bodyshell to F150 flareside. I want speed more than anything just to bash at home but on a really tight budget. My question is with the firebolt 15t which pinion gear would be optimal as now it has a 48p 22t with 65t spur gear. Lower turns is supposed to be faster but when I still had the 27t motor I could run a 33t pinion and the top speed was alot faster than it is now. Any recommendations? And don't say brushless as it isn't in the budget.
lauderman is offline   Reply With Quote
Old 01-05-2012, 12:50 PM   #2
superspeed's Avatar
Those fireball mod motors are easily to overheat, I never think they were good quality but too bad there aren't too many mod motors (brushed) available. You dropped from 33 to 22 on the pinion gear size, that's a huge change. If your car tops out right away, then it's undergeared. Try 26 - 28 tooth for pinion gears range.
superspeed is offline   Reply With Quote
Old 01-05-2012, 12:54 PM   #3
superspeed's Avatar
Furthermore, Tamiya still make the 23 turn spec racing motors (RZ, TZ, RR). They are better choices than the cheap quality venom fireball motors.
Old 01-05-2012, 12:57 PM   #4
22t is around the limit with this motor i think considering it tends to overheat and shutdown after longer runs. Will dropping to a 20 or 21 help by relieving some of the load and increase speed or should I go with say a 20t motor and gear bigger?
Old 01-05-2012, 12:59 PM   #5
I have an HPI firebolt 15t not a venom fireball.
Old 01-05-2012, 12:59 PM   #6
you could of melted plastic ball bearings......e10 first upgrade should be ball bearings
urban is offline   Reply With Quote
Old 01-05-2012, 01:03 PM   #7
Bearings are on my list of upgrades. I am also considering going lipo, but the esc program instructions are hard to follow and dont understand them.
Old 01-05-2012, 01:10 PM   #8
Anyone know how to program the HPI sc-15wp esc for lipo battery???
Old 01-05-2012, 01:15 PM   #9
also are there any brushless systems out there that are fast and for a budget that i could squeeze into this car? i will be happy when i can break 50+ with this car.
Old 01-05-2012, 02:40 PM   #10
Would the Associated 540R 6100kV Motor and esc get me close to 50+ on nimh battery or would lipo be required?
HPI E10 riceman777 Electric On-Road 12 03-27-2013 10:31 PM
Comment about the hpi E10 Touring von Electric On-Road 33 10-13-2012 11:10 PM
NEW HPI E10 DRIFT AND E10 TOURING xsxracing Electric On-Road 29 01-30-2011 12:22 PM
HPI E10 = Raceable??? hrnts69 Electric On-Road 13 01-06-2009 11:53 PM
HPI E10 vs TT01 joe of loath Electric On-Road 13 11-15-2007 04:27 AM
