In Stock, punch matter. But how can we get it. >
Old 12-26-2004, 12:39 PM
Default In Stock, punch matter. But how can we get it.
In Stock, punch matter. But how can we get it.???
Can you help. ???
racerkorer is offline
Old 12-26-2004, 01:19 PM
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Randy Caster is offline
Old 12-26-2004, 01:38 PM
Put harder springs on.
I don't like excessive torque/punch as I like high revving motors. Just my opinion.
Jan Larsen is offline
Old 12-26-2004, 02:01 PM
ddesros2's Avatar
Dead short you batteries.
ddesros2 is offline
Old 12-26-2004, 02:34 PM
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
give it a kick up the backside
Or you can put some boxing gloves on
MR JOLLY is offline
Old 12-26-2004, 02:36 PM
protc3's Avatar
build your motor correctly by starting with a fresh cut comm,new brushes(i like 767's or 4499's),proper spring tension and shim the motor.next you will need good batteries with high voltage.and of coarse,a nice smoothe,free drivtrain.with a belt drive you run the belts pretty loose for minimum drag and with a shaftdrive you need to hand work your cases and shim the gears.
protc3 is offline
Old 12-26-2004, 02:38 PM
protc3's Avatar
also,dont forget to fully seat the brushes by breaking the motor in at low voltage.i usually break it in at 2-3 volts.hope this helps.
protc3 is offline
Old 12-26-2004, 03:23 PM
Put more amps to your charger. That will nicely give some punch more, but naturally will decrease your batteries lifetime. I did charge with 6.5 or 7.0A for stock when I was still racing there. That was all my charger was able to give.
copter is offline
Old 12-26-2004, 03:25 PM
Good volts on cells and a clean fresh motor (cut comm, re lubed etc etc)
Chazz
Chazz is offline
Old 12-26-2004, 04:05 PM
TL_XXX-S_racer's Avatar
You can change gearing to where u get more punch out of the car. Another way is to look at the readings when u buy a motor and find a motor that has alot of punch.
TL_XXX-S_racer is offline
Old 12-26-2004, 04:54 PM
ChadCapece's Avatar
Harder springs won't always give you more torque. It can decrease torque on some motors. I just did a monster stock, in which Red+ and Black- gave me the best readings.
ChadCapece is offline
Old 12-27-2004, 11:53 AM
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Lower your drive frequency.... Try a Tekin!!!
sg1 is online now
Old 12-27-2004, 12:00 PM
ChadCapece's Avatar
Or setup your esc for punch stock mode. I doubt that is the stock setting on most.
Old 12-27-2004, 05:33 PM
imjonah's Avatar
Default huh
What is "punch stock mode" How would you program this on an ESC ?
imjonah is offline
Old 12-27-2004, 06:07 PM
protc3's Avatar
which speedo do you have?
protc3 is offline
