Old 06-16-2002, 04:38 PM   #1
Default KO ESC/Servo wiring question
I have a KO ESC ( VFS 2000) that I am trying to set up with my Airtronics receiver (Z type). Can anyone help me with the correct wiring for the Airtronics receiver? I have checked several websites and they each list a different color sequence, I dont want to damage the ESC and the instructions included in the box does not mention using anything othere than KO equipment.
Thanks for the help
Sting is offline   Reply With Quote
Old 06-16-2002, 04:58 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Black is the ground wire, and on an Airtronics Z type connector you'd want it to go closest to the edge of the receiver nearest the sockets. Red is the positive, it goes in the middle, and white (or whatever the third color is for a KO ESC) goes furthest from the edge of the receiver case. The Z connector wiring sequence should be the same as the KO, Futaba, and JR. Only the older Airtronics used a different wiring sequence in the connectors.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-16-2002, 06:50 PM   #3
Super Moderator
Grizzbob's Avatar
Yeah, the Futaba "J" connector wiring pattern has become the modern standard lately, so it makes it a LOT easier to just plug in a servo & go.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-16-2002, 09:57 PM   #4
Trips
Thanks for the quick reply!! it helped
Old 06-17-2002, 05:52 AM   #5
STLNLST's Avatar
Trader Rating: 21 (100%+)
You don't have that car together yet???
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
7.2 v KO servo wiring & PT wiring issues bshookup Radio and Electronics 2 06-12-2008 01:23 PM
fan wiring question J&L Johnson Electric On-Road 13 01-29-2007 04:33 AM
EVX wiring question redlinezak Monster Trucks 4 02-23-2006 12:29 PM
Wiring Question...Also...TC4 Carpet setups Soviet Electric On-Road 8 10-12-2005 10:18 PM
Quantum Reverse Wiring Question rinkrat99 Electric On-Road 1 05-14-2005 02:30 PM
