Old 01-03-2012, 03:48 PM   #1
Norman2's Avatar
Default New Oval Class for 2012
Hi, Our Local track is planning a new Nascar oval class starting with Spring
weekly races. Rules are as follows in an effort to keep cost down and attract our younger kids into the sport. Rules are:
1- Any 1/10 scale 200 MM pan car chassis
2- 15T Modified brushed motor any brand
3- Duratrax Intelli speed 12T Modified ESC with reverse lock out
and zero timing.
4- NIMH Six-pack 5000 MAH any brand
5- Foam tires by BSR or Jaco any compound.
6- NASCAR body by Protoform painted to resemble a current
Sprint Cup or Nationwiade series champ
In adding up the price of everything needed for a competitive class it
is very cheap when comparing to a similar Brushless/Lipo car.
After the announcement, we have received input that 26 cars are being
built just for this class. These are older guys that race in the modified B/L class that are building cars for their sons and grandsons, even for
some Grandaughters. I completed a CRC Genx-10LE for my grandson
to race.(12 years old) and have attached photos of the car and chassis.
If anyone has some suggestions to improve the rules please let me know. Regards
Norman2
New Oval Class for 2012-img_0002.jpg   New Oval Class for 2012-img_0003.jpg   New Oval Class for 2012-img_0001-1.jpg
Norman2 is offline   Reply With Quote
Old 01-03-2012, 03:55 PM   #2
For_the_win's Avatar
and zero timing.
Norman2
Small tip, get rid of those batt plugs and replace with deans or trx connectors
For_the_win is offline   Reply With Quote
Old 01-03-2012, 04:01 PM   #3
Chaz955i's Avatar
Try posting in the oval section. You are likely to get more responses. Good luck with the class.
Chaz955i is offline   Reply With Quote
Old 01-03-2012, 04:39 PM   #4
AE-Reedy
You'll need to make some kind of rule about battery position or you will immeadiately be swamped with true oval chassis being adapted to the class.
Or you need a weight bias rule.
Also would recommend trying to use a Spec tire. Both BSR and Jaco have Spec foams, will save a lot of money.
Sean Cochran is offline   Reply With Quote
Old 01-03-2012, 04:40 PM   #5
Norman2's Avatar
Hi, Thanks, connectors will be changed before first race.
Old 01-03-2012, 04:44 PM   #6
Norman2's Avatar
Originally Posted by Sean Cochran View Post
You'll need to make some kind of rule about battery position or you will immediately be swamped with true oval chassis being adapted to the class.
Hi, Thanks didn,t think about that. Have to figure out some way to keep away from weight bias rules. Any suggestions? WE can change the rules
to spec tire. Escellent idea. Thanks
Norman2
PS. We actually run the same class with 13.5T B/L and open ESC and offset cars don't show any
advantage over centered chassis. The CRC GenX-10LE is just as competitive as the CRC-Battle Axe
which is a dedicated oval chassis. Maybe you are correct and it will show up with the Brushed motors.
Again thanks for you suggestions, Regards
Norman
Old 01-03-2012, 04:45 PM   #7
trerc's Avatar
Trader Rating: 89 (100%+)
Car looks to have BSR spec tires on it...But I definitely agree, SPEC the tire!
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-03-2012, 05:25 PM   #8
CraigMBA's Avatar
Trader Rating: 22 (100%+)
and zero timing.
Norman2
Six cells and a 15 wind is going to be insanely fast in a straight line - like faster than 10.5 1s fast. Even a stock motor (27 wind) is going to be too fast Brushed motors on oval need to be turned every run or two runs else they start eating themselves, which gets costly.
And if that's not enough, these cars are going to be very hard on tires, bodies, and parts because of the weight combined with the speed. . When we ran 21.5 2s no timing it was too fast for a lot of guys, although it was durable. Something else to consider - these cars are going to be impossible to practice with for the other classes unless you are running controlled practice.
I suggest you run a 1s class that mirrors the 1s Spec Truck series. That combination works and is fairly inexpensive because it's easy on parts, and there's no black magic in the tires.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-04-2012, 05:27 AM   #9
Norman2's Avatar
Hi CraigMBA, Can you please let me know the rules for 1S Truck spec
class. From what you have pointed out it seems it may be better to
go that way. Going probably to 17.5 brushless with a not too costly ESC
will be cheaper in the long run vs. replacing a lot of brushed motors.
Will appreciate your suggestions as have to finalize the rules before
the end of January. Thanks
Norman2
Old 01-04-2012, 05:46 AM   #10
trerc's Avatar
I agree that would be best, I would use BRL sportsman truck rules as a guideline
17.5 Sportsman Truck
5.1.2) The only battery allowed in the 17.5 Sportsman Truck class is the SMC 4000 Mahr, 25C single cell Lipo (PN SMC4025).
5.1.3) Any 17.5 turn, sensored, brushless motor approved by ROAR may be used in this class. A list of approved motors may be found at:
http://www.roarracing.org/?page_id=251
5.1.4) Electronic Speed Controls used in this class must be approved by ROAR for use in sportsman racing. When used in any practice or competition for this class these ESC‟s must be set to their sportsman or zero timing advance mode. A list of approved ESC‟s can be found at this link:
http://www.roarracing.com/?page_id=737
5.1.4.1) Wirelessly programmable Electronic Speed Controls are not allowed in this class
5.1.5) World GT Tires are the only tires allowed for use in the TOUR Sportsman Truck Class. World GT Tires are to meet the following specifications:
5.1.5.1) Tire compound to be Japanese R4 compound, 38 shore
5.1.5.2) Tire must have an identifier ring of purple colored foam visible around the circumference of the tire
You can of course alter these a bit to fit to the cars, I have removed the portion about bodies as these wouldn't apply to your class
Old 01-04-2012, 06:16 AM   #11
nrtv20's Avatar
I agree with the BRL rules.
http://www.hobbytalk.com/bbs1/showthread.php?t=339047
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-04-2012, 06:30 AM   #12
Norman2.....
Looks like everyone covered everything you need for a fun class for you all.......good luck with it. We all run the Sportman Truck class (with there rules) with an expensive Hobbywing 1s ESC and a 1s lipo with spec tires. Racing is very equal and real fun!!!
By the way.......nice pic on the wall in the background of the red open wheel car.
all4fun is offline   Reply With Quote
Old 01-04-2012, 07:32 AM   #13
bakaguyjean's Avatar
and zero timing.
Norman2
looks expensive to me
bakaguyjean is offline   Reply With Quote
Old 01-04-2012, 07:37 AM   #14
Buckaroo's Avatar
If you've never run oval, that car that you have is going to be a fist full of dynamite (with similar results)!
We're trying to get oval started back up at my track, too, and we've loosely agreed to go with the TOUR/BRL truck rules. I've run my truck a few times, and for starter oval, it's lots of fun and really suprisingly fast.
For some rules sets that have proven rather robust and LOTS of information on everything oval, head over to the Oval section at Hobby Talk: Click Here
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-04-2012, 11:19 AM   #15
Norman2's Avatar
Hi, Guys Thanks for all your inputs. I think we will change to Sportsmans
Truck Rules
1-Nascar type bodies
PT Raceway NEW TRACK Level Green, Murrsyville, Pittsburgh, Penn Trafford, Irwin Ostach24 Track Locator Forum 1518 12-18-2014 07:23 AM
2012 1/16th Traxxas COT. D&D Race Micro and Mini Scales 41 03-04-2013 10:53 AM
Cheese City Xtreme - Indoor Clay Offroad and Oval Racing - 2011-2012 Season Benny 13 Wisconsin & Illinois Racing 724 04-06-2012 01:44 PM
ROAR blinky rule for 2012? Outtacontrol58 Electric Off-Road 152 01-04-2012 10:07 AM
