Old 01-03-2012, 10:23 PM   #16
syndr0me's Avatar
Trader Rating: 32 (100%+)
There's also concerns about chunking foam tires.
syndr0me is offline   Reply With Quote
Old 01-03-2012, 10:37 PM   #17
Suspended
We have been using dots in less quantity for awhile, it's rad.. simple as that.
Wes Briscoe is offline   Reply With Quote
Old 01-04-2012, 05:55 AM   #18
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
click track occasional dots to mix it up.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-04-2012, 06:20 AM   #19
Originally Posted by artwork View Post
Can you post or link some pictures?
great input thanks
What a great looking track...
I will see how this works out. The pics are from a couple of our races.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 01-04-2012, 07:36 AM   #20
Buckaroo's Avatar
Where is everyone getting the flexible plastic stuff?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-04-2012, 10:22 AM   #21
industrial plastic supply houses for the LDPE sheet.
NORCAR @ The Gate
Old 01-04-2012, 10:45 AM   #22
Originally Posted by bkspeedo View Post
Kody,
Keep us posted on how well it works. It's very hard convincing people at our track that this type of barrier system is beneficial. Everyone is worried about the dots moving and launching cars if there hit.
I for one don't believe this will happen.
Will do.
3-4 strips of Velcro on the bottom and there good to go. Velcro is placed so the dot lays perfectly flat and the edge of the Velcro grips the carpet fibers. They tend to stay put very well. Losi dots have a very smooth edge unlike steel plow discs. Cars handle Losi dots extremely well unlike any dot I've seen. 12th scale one of our largers classes handle them fine with no chunking problem. In fact hard corners IMO chunk stuff the worst...
Additionally whats nice about dots is you see your full car going through corners. Just watching ETS and the ATS race make you think about how cool that is!
Kody is offline   Reply With Quote
Old 01-04-2012, 10:49 AM   #23
Regional Moderator
CarbonJoe's Avatar
The click track, while easy to change layouts with, has corners that are very hard on cars.
The LDPE/UHMW plastic flappers, on the other hand, are extremely forgiving. Hardly any breakage when using them. We use painted, doubled up 2x4s for the barriers, with the LDPE flappers. Also, we use velcro on the bottom of the 2x4s to help hold them in place on the carpet.
At the Indoor Champs, they screwed through the click track into the subfloor to hold everything in place. If CRC would make corners with the LDPE flapper material, that would be ideal (as long as you have a way to secure the barriers in place). Expensive, though.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-04-2012, 10:54 AM   #24
That or local plastic shops. Its cheapest to buy a full sheet and rip it into strips. UHMW is the best but not necessary. Your shop will recommend something that's very close and works well. 1/8" works great for smaller flappers and edging hard wood made corners. 1/4 or 3/8" can be used to make a single layer large corner say coming off a straight into a sweeper. Our old layout used two long 3/8" strips bolted in the center for a nice large sweeper entry. Had a nice spring to it encase you turned into it.
Old 01-04-2012, 01:07 PM   #25
bkspeedo's Avatar
Originally Posted by Kody View Post
Will do.
This is exactly what i've been trying to convience races of at our track but now one wants to listen. They think these low profile Losi dots are going to act like plow disks and launch cars, some people are so one sided. Others feel the velcro or tape will damage the carpet, I don't believe it will. Our track in Fort Collins uses velcro to hold pipe in place and it hasn't damaged the carpet after 4 years of use.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-04-2012, 01:45 PM   #26
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
http://www.losi.com/Products/Feature...rodId=LOSB1013
That looks awesome.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-04-2012, 02:02 PM   #27
Its all about the correct dot and Losi just so happens to make it. There might be a dot out of Asia that works as well but Losi's are cheap and easy to get! Velcro is the key to our track. If not for it we would have hundreds of pounds of weight everywhere on the track. SRCR H30 carpet track is built each night and taken down. No bad side effects have been seen...
Old 01-04-2012, 03:16 PM   #28
Trader Rating: 24 (100%+)
GOOD LORD !! Is that ACTUALLY a hangar you guys have ?? How on earth did you make THAT deal ?? Gotta check out your thread.
Evoracer is offline   Reply With Quote
Old 01-04-2012, 03:29 PM   #29
samshirley00's Avatar
At my local, we are only a small club, and we basically just use old guttering on carpet bolted together
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 01-04-2012, 03:56 PM   #30
Magnet Top's Avatar
I was able to run a few packs on our new layout with the Losi dots.
These ****little LOSI dots**** are not launch pads at all but they do slow the car down so you don't want to drive over too many of them because it will penalize you so a faster driver that drives clean will probably have a good opportunity to pass. Its kinda perfect if you ask me, but we have yet to race with 10 cars... so we'll see.
There remains one hard corner on our track( without any dots ). During the practice day this hard corner was the only reason any cars crashed wildly and tumbled out of control. The Losi dots just made the car hop and slow down. I actually don't think I saw a car flip over from the Losi Dots! Once traction comes up that may change.... probably not... but you get the idea. They aren't launch pads ! They actually act like big car FIA berms .. they slow you down but don't cause a wreck.
Yup, its Hangar 30 at the old Sand Point Naval base but now it is run by the Seattle Parks Department. Our club president, Todd Mason, has done an amazing job cultivating a great relationship with the parks department. So far our race fees easily cover the rental costs. Also we are in the process of building a permanent asphalt road course around SeaTac airport.
Jake D.
Magnet Top is offline   Reply With Quote
Durango DNX408 - Fast enough to win the World Title. TeamDurango Nitro Off-Road 10039 01-28-2017 02:01 AM
Bending Corners Raceways, Carpet, Asphalt, We got it! TireShredder California Racing 7617 10-07-2013 11:37 PM
Traxxas at Toys R Us What's the world coming to? cbr74 Chat Lounge 139 06-26-2011 07:12 PM
New Track updates TSB Northwest Racers 122 08-29-2003 10:52 PM
