Old 01-02-2012, 02:18 PM   #1
Default DRIFT TIRES
So ive searched trying to find it, if anyone has any links im open to checking them out. What Im interested in is finding out which drift tires you like, on which surface?
smooth fresh asphalt
old rough asphalt
slick concrete (ie garage floor)
textured concrete (driveway or sidewalk)
carpet
just looking for more info, why do you like the certain tire on whichever surface, and whatnot.
Chris
csweattgo is offline   Reply With Quote
Old 01-03-2012, 04:25 AM   #2
blettres's Avatar
Default drift wheels
i use pvc pipe on my standard TT-01 and it is good surfaces i dont like rough ahphelt cos of all the small rocks and stuff. i am about to upgrade the motor so i need a softer plastic but i will be makeing them the same way.
How to make them.
1. buy 4 new rims or use old ones
2. Remove all the lips apart from the last one on the inside it is best to do this on a lathe
3. Find some pvc pipe i use pipe with a 53mm id and cut to the with u like
4. it is best to round off the out side edge
5. use tale around the rim to make sure it is a tight fit i have never glued them on.
6. do this 4 times and then go drifting
Tamiya TT-01 d Nissan Silvia (race / drift car)
HBX Rockfighter (rock crawler)
blettres is offline   Reply With Quote
Old 01-03-2012, 04:38 AM   #3
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Also check out Raikuo (sp?) on Staten Island, they have a good selection, and they ship quickly.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 01-04-2012, 02:09 AM   #4
blettres's Avatar
Default Drift wheels
Ok so i found some poly pipe today with a 53mm id going to try and make some wheels tonight
Old 01-06-2012, 04:34 AM   #5
blettres's Avatar
Default Polly drift wheels
OK so i made some Polly drift wheels and they are much better than pvc.....
heaps of grip off the power and hit the throttle and watch that ass slide. now i just need my bigger motor to turn up....
FS New Hpi Subaru Wrx body, rims and drift tires Shameless121 R/C Items: For Sale/Trade 50 04-18-2012 09:18 PM
Yokomo AE86, HPI TE37's w/ yokomo drift tires grapejuice R/C Items: For Sale/Trade 6 11-24-2009 01:06 PM
Tips for installing HPI T-drift tires Cheezburger Electric On-Road 18 06-08-2009 07:58 PM
