Old 12-24-2004, 11:41 AM   #1
LosiRacerX's Avatar
Default CRC T-Force
is this a strong well built car because i want one but my club leader cant get parts for them so i would have to order spare parts its all graphite so i figure its strong but the t-bar and bottom plate is wut im worried bout, i had a reflex 12 and broke a bottom plate and front bumper and top plate dont ask it wus a hard hit so i want a stong car so im looking towards a crc car preferably a 3.2r or a t-force
LosiRacerX is offline   Reply With Quote
Old 12-24-2004, 12:20 PM   #2
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
??? ok
uhhh.... its a good car....
OUT
Keith Billanti is offline   Reply With Quote
Old 12-24-2004, 04:25 PM   #3
LosiRacerX's Avatar
have u broken anything on it yet?
Old 12-24-2004, 04:53 PM   #4
John_S's Avatar
i think t bars will break as easily on all t bar cars because they are made ofthe same material unless u get an aftermarket spring steel t plate
John_S is offline   Reply With Quote
Old 12-24-2004, 04:58 PM   #5
LosiRacerX's Avatar
well it is graphite so im thinkin that would atleast make it atleast a lil stronger than fiberglass
Old 12-24-2004, 05:25 PM   #6
I run the car as an L car with tubes.. meaning .075" glass Tbar. No side springs.
you will find the thicker chassis is more consistant on carpet, carries a bit more corner speed...
the aluminum is beutiful... period.
the bearings are rediculous.. my car is 4 months old.. and the rear axle still will find the heavy spot on the wheels.
breaking a 1/12th scale car? uh.. nope
its pretty indestructable...
KB
OUT
Old 12-24-2004, 05:27 PM   #7
LosiRacerX's Avatar
well my friend did the ca glue thing to his reflex 12 and he hasnt broken anything yet and i didnt and broke stuff so i wondered if igot this car and a t bar and a bottom plate or i just get a rev4 instead of of the t-force cuz the rev 4 looks pretty simple
Old 12-24-2004, 06:50 PM   #8
nashrcracer's Avatar
R/C Tech Charter Subscriber
the tforce comes with a graphite tplate and you can use it it's the same thickness as a 065 and works like a 072 as it is also stronger then a 072 as it is graphite. I woulnd't think you would want a 3.2 as it's a little less likely to take a hit like you have taken. I would suggest getting a bottom plate when you buy your car. and yes you should use a toothpick to apply super glue to the edge of your bottom chassis parts. this helps seals the edge and helps to keep it from chipping and fraying. I have 3 tfource cars and I have been racing for 19 years and I still break tplates so you might get a couple of them also.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-24-2004, 10:12 PM   #9
dakrat's Avatar
CA gluing will only help for chipping and flaking of carbon fiber, it will not prevent breaking. any car will break if u hit the right object at the right speed. i have reflex 12 i didnt do the CA gluing thing, i dont hit walls very often and i still have it.
dakrat is offline   Reply With Quote
Old 12-25-2004, 07:25 AM   #10
whynot's Avatar
Trader Rating: 18 (100%+)
Does anyone put super glue on the edges of the tplate to add strength. Just curious.
mike
whynot is offline   Reply With Quote
Mad Force Torque R/C Items: For Sale/Trade 29 09-17-2010 10:26 PM
CRC T-Force biker R/C Items: For Sale/Trade 4 02-26-2007 09:31 PM
Wanted TXT or Twin Force / Mad Force axles ffactory666 R/C Items: For Sale/Trade 0 12-19-2005 03:38 AM
Complete Twin Force/Mad Force axles..... Phatkat R/C Items: Wanted to Buy 0 08-19-2005 12:30 PM
Kyosho Mad Force/Mad Force RCX editon TRF-Powered Monster Trucks 1 08-07-2003 07:58 PM
