Radio glitching
Old 12-24-2004, 10:25 AM
Default Radio glitching
I'm having a strange problem with the electronics in my TC3. I've been using these electronics for a couploe years now and never had a problem. However, today I started working on moving everything over to a new car. My current car is a plain old Factory Team TC3. The new car is a TC3 with a carbon fiber BMI Racing chassis.
I installed the electronics in the new car and powered everything up without any problems. The problem happens, as I add throttle. The motor as well as the steering will periodically glitch for about half a second. There doesn't seem to be any rhyme or reason to when it does it although it seems like its more prevelent at higher speeds. Obviously, at speed on the track this could spell disaster
Could the carbon fiber chassis be making my reciever glitch? Both the receiver and transmitter are JR Racing units and they're only a couple of years old.
plbman is offline
Old 12-24-2004, 11:31 AM
howard hudson's Avatar
Default Re: Radio glitching
yes the CF chassie could cause glitching. It acts like a conductor. try useing at least three pieces of servo tape when mounting your electronics. Or get a yokomo noise filter they run about 20 bucks from speedtech.
good luck
howard hudson is offline
Old 12-24-2004, 11:54 AM
if your antenea is touching the cf top platre you'll get glitching also
sportracer is offline
Old 12-24-2004, 06:20 PM
KREATOR1's Avatar
i had one of these problem before, but after cutting the motor comm. It will work fine again , and no glitch.
Also you may have to change your radio antena
KREATOR1 is offline
Old 12-24-2004, 06:27 PM
ntc3freak's Avatar
slide a piece of fuel tubing where the antenna touches the carbon fibre.hope this helps
ntc3freak is offline
Old 12-24-2004, 07:10 PM
hpipro321's Avatar
or you could cut a small hole in the antena tube just big enough for the antena to fit in there and cover exposing wire with shrink wrap
hpipro321 is offline
Old 12-25-2004, 12:57 AM
Team Duratrax's Avatar
Put a few capacitors on your motor and clean out all the electronics,capacitors help stop glitching considerably
Team Duratrax is offline
