Old 12-24-2004, 09:30 AM   #1
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default Tamiya Tyre Warmer
hi all,
i need help on the tamiya tyre warmer. Any of you guys used it before?
It says that i have to plug in to a 7.2 1200mh batt. using tamiya connector. Seem like i cant find any of tamiya connectors.
what if i plug it direct to the 12amp 12V power supply?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 12-24-2004, 09:37 AM   #2
X2
X2's Avatar
You would probably get some VERY hot tyre warmers!
Change the connecters and just use any 7.2V pack
X2 is offline   Reply With Quote
Old 12-24-2004, 09:39 AM   #3
KREATOR1's Avatar
im think using direct to power supply like the speedmind tyre warmers.
Old 12-24-2004, 09:49 AM   #4
i use the eagle tyre warmers and it says to use 7.2v battery but i put it on a 12v power supply and they seem ok.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-24-2004, 09:49 AM   #5
KREATOR1's Avatar
pict
Old 12-24-2004, 09:54 AM   #6
KREATOR1's Avatar
thanks man ,
For how many minutes you put it onn before race?
it says here , it will be around 60c when being used.
Old 12-24-2004, 10:10 AM   #7
i put my tire warmers on the power supply constantly.there always on.
as to how long you have them on the tyre for depends on tyre compound amount of additive you use and the amount of traction.
i use them with the old t27 tyres from m1 racing as these are a control tyre and there compound very hard so even on carpet traction is still low.[the only reason we use t27 in the uk is because it seems the organisers are scared of using a additive on the carpet for slick tyres thefore the only next tyre they know of which is good on caropet without additive is the t27].the tyre warmers get up to about 75 degrees c which is ok for this type of compound but if your using something like a cs22 or even a cs27 that temp may be too much a may damage them.if i were you id just experiment and see what happens.
i havent done much experiments with them so iam still learning lol.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 12-24-2004, 10:17 AM   #8
KREATOR1's Avatar
hey thanks again,
I will try it this weekend on the warmer
thanks
Old 12-24-2004, 06:53 PM   #9
cooliomojo-CEBU's Avatar
would like to know the advantage of using dgital tire warmers? how big an advantage do these really expensive tire warmers have over the ordinary tire warmers?
cooliomojo-CEBU is offline   Reply With Quote
Old 12-24-2004, 06:56 PM   #10
U can set the temperature u want for the digital tire warmer. The ordinary don't have this.
Nella-Nobrob is offline   Reply With Quote
Old 12-24-2004, 07:14 PM   #11
KREATOR1's Avatar
But the tamiya tire warmers will stay up to 60C and the speedmind will keep onn warming untill you switch it off.
Old 12-24-2004, 08:46 PM   #12
Entropy's Avatar
Tamiya warmers may go higher if u plug them to 12V.
Entropy is offline   Reply With Quote
Old 12-24-2004, 08:48 PM   #13
KREATOR1's Avatar
i just put it around 5 minutes . just to make 1-2 first lap warm.
cheers!!
tc5 with spares tc speedie ctx tyre warmer driftnerd Australia For Sale/Trade 1 10-07-2008 02:02 PM
CHARGERS, POWER SUPPLY, TYRE WARMER hungry Australia For Sale/Trade 0 07-09-2008 05:13 AM
Tyre warmer temperature? PRO 2 RACER Electric On-Road 4 09-28-2007 07:27 AM
Tyre Warmer Help vazzo Australian Racing 2 07-02-2007 06:36 AM
Help! tyre warmer controller jamie814340 Electric On-Road 1 07-22-2006 02:12 AM
