Old 12-29-2011, 04:10 PM   #1
Default drifting
I have a xxxs graphite addition is it a good drifter
havenfun is offline   Reply With Quote
Old 12-29-2011, 04:19 PM   #2
snoopyrc's Avatar
Any TC can be a good drifter. You just need the right set up and tires, plenty of power.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 12-29-2011, 04:24 PM   #3
Recommendation 4 drift tires?
Old 12-29-2011, 05:38 PM   #4
HPI T drifts or Sushi drift tyres can be picked up on ebay 12 tyres for around 20 dollars
"No matter if you win by a inch or a mile, winnings winning".
AleD123 is offline   Reply With Quote
Old 12-29-2011, 08:45 PM   #5
Sweet thanks now how about you motor. Turn gear. Pitch
Old 12-30-2011, 08:49 AM   #6
Any suggestions About motor in gearing
Old 12-30-2011, 08:51 AM   #7
pettyeagles's Avatar
Trader Rating: 82 (99%+)
19T brushed or 13.5 brushless.
A bad day racing beats a good day at work. My RC fleet:
SC5M(x2), B5M, SC10.2, FT SC10, FT TC5, FT TC4, 12R5, AE Rival MT, RC10 Classic, RC10 Worlds, CW Pro Comp Outlaw, F104 pro v2, RJ Speed Legend, Traxxas Slash(x2), 4x4 Slash VXL, Vendetta ST, Axial SCX10, Yeti, Smt10, G-Made/AX10, Tamiya Super Clodbuster
pettyeagles is offline   Reply With Quote
Old 01-01-2012, 10:21 AM   #8
How about the gear pitch
Old 01-01-2012, 07:20 PM   #9
narcotiks's Avatar
The gear pitch doesn't make any difference on speed if that's what you were wondering . It just depends what ratio you would like to use. 48 pitch is generally a tad easier to achieve perfect gear mesh than 64 pitch, but it still depends what ratio you want and what will fit.
narcotiks is offline   Reply With Quote
Old 01-02-2012, 07:57 AM   #10
I'm sure you were not meaning to say mesh but ratio. 64P is just as easy to set mesh on as 48P the difference is that with the finer teeth you have more steps in selecting a ratio. 48P is a nice compromise between 32 and 64P and is more durable than 64P.
AreCee is offline   Reply With Quote
Old 01-02-2012, 08:43 AM   #11
My? Was bigger. Off the motor. Or smaller.
Old 01-02-2012, 10:22 AM   #12
snoopyrc's Avatar
Find out what pitch your gears are. Or you can decide that you want to use say 48 pitch gears. You can put a 48 pitch spur gear on it and then buy some 48 pitch pinion gears. You can do the same with 64 pitch but the spur and pinion gear have to be the same pitch.
If you are getting a whole lot of punch but no speed go to a bigger pinion.
If you are getting a lot of speed but no punch then go smaller on the pinion.
If your motor is getting to hot to touch then go to a smaller pinion.
The pinion is the one that goes on the motor.
RC Drifting Section briangomez931 Manila Racers 10549 05-30-2015 03:36 AM
Professional Drifting with R/C cars! MartinSorlie Electric On-Road 98 11-14-2013 02:39 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 10:34 PM
1/10 & 1/18 RC Drifting Speed Demon Malaysian R/C Racers 115 06-22-2009 11:16 PM
Brushless Combo for Drifting stylomilo Singapore R/C Racers 189 03-12-2009 06:55 AM
