What does it effect on changing the rear shock position?
Laying them down gives more lateral grip in the rear
Read this. Print Touring Car Setup Guide. http://home.scarlet.be/~be067749/58/ |
Laying them down gives less rear traction on the way into the corner, but more rear traction under power.
it depends :)
Originally Posted by ioxqq
(Post 10065426)
First, when you laydown shocks you will end up with a softer and more progressive spring rate. More progressive means that as the suspension gets compressed the spring rate increases faster. Also, if you attach the shocks to the inner hole on the a-arms, this will also soften the effective spring rate. The reason why this is an "it depends" answer, is that sometimes when you soften the rear suspension this can increase rear grip and sometimes it can take away rear grip. If the rear is too soft and the rear of the car rolls over too much it will loose lateral grip at the rear, because there is too much of a difference between the vertical load on the inside and outside tires. This is less of an issue while entering a corner as most of the weight is transferred to the front tires in this situation. However as you start to apply throttle in the middle and exit of the corner if the car rolls too much in the rear due to overly soft spring rates, then you may loose rear grip. laying down the springs will also make the car feel more lazy when transitioning in chicanes compared to the same spring being stood up. My setup app "RC Setup Workbench" available on IOS (iPhone and iPad) or Android devices help explain this among many other points about setup. |
I seen Martin Crisp setup on the smart phone, as my friend has it downloaded. VERY impressive app. gives me another reason to end my contract with my service prvider and get an I Phone.
+1 on Matins app, I'm now able to positively adjust my car to work on every track we run on. Has allowed me to progress from an average racer to one that can compete for the win each week. Well worth the $10 I spent..:)
Martin Crisp. Just brought it thx
