Old 12-20-2004, 03:08 PM   #1
xray t1r high grip setup
hi there i was just wondering if anyone has a really good setup for the t1r. i need the car to generate as much grip as possible. if you have any wet setups aswell would help greatly.
thanks
soto is offline   Reply With Quote
Old 12-20-2004, 03:15 PM   #2
ChrisP's Avatar
You may want to consider posting this on the Xray T1 thread with some specifics on what type of surface you'll e runing on, type of track layout if it's for a track as well as any restrictions that you must run (such as rubber or foam tires)
ChrisP is offline   Reply With Quote
Old 12-20-2004, 03:21 PM   #3
ok sorry im new
Old 12-20-2004, 03:30 PM   #4
Trader Rating: 45 (100%+)
Default high bite setup for xray t1 fk
Carpet Setup
Apex is offline   Reply With Quote
Old 12-20-2004, 03:56 PM   #5
ChrisP's Avatar
The setup for the FK uses short arms and low ratio pulleys and the T1R uses long arms and regular pulleys...
Josh's setup won't really apply too well....
Let's bump this back over into the T1 thread though...
soto...wasn't trying to be mean.....on the contrary..welcome to the site...
I just thought that on that thread you may have a better chance of response....
Also if you better explained the track conditions that you'll be running (ie. the surface - carpet or asphalt) and whether you need rubber or foam tires that a response could be given that will best suit your needs
Trying to find cs electronic high grip? J.Gonzalez Electric On-Road 3 01-30-2008 03:04 PM
NEW Yokomo High Grip Drift Radial Tires ZR-080D jojo RRR Electric On-Road 0 06-30-2007 06:16 PM
High Grip Asphalt Setup for TC4 RCpurplecow Electric On-Road 2 11-14-2006 10:33 PM
High End TC for high end off road setup.... losirunner R/C Items: Wanted to Buy 0 12-04-2005 08:00 PM
PRO4 HIGH GRIP CHASSIS MikeR R/C Items: For Sale/Trade 3 10-22-2005 02:27 PM
