Old 12-20-2011, 08:34 AM   #1
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Default Novak stator issue?
Just got a new epoxy dipped 17.5 stator in last week.
I went to build the motor Saturday and could not get the pinion side bearing cap to seat with the stator.
I assumed it was just a case of the epoxy being a bit heavy on that side of the stator..so after carefully knocking down some of the epoxy I tried again.
Still no luck.. Upon further inspection I found that the cap was actually hitting the non tab side of the stator because the stator was longer than
the non epoxy one that was in there (see pics).
I have tried everything but sticking the stator in a vice and crushing it down (did not want to break the epoxy) but the two end bells will not bolt together because of this.
I have sent two emails to Novak but have not gotten a reply yet.
Wanted to see if anyone else had this problem and if there was anything I could try before I call them later today.
Novak stator issue?-novakk-medium-.jpg   Novak stator issue?-novak-small-.jpg   Novak stator issue?-nov-small-.jpg
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 12-20-2011, 08:45 AM   #2
Johnny Wishbone's Avatar
Try to put it together without the paper gasket between the stator and the endbell.
Contact Charlie via his email is the best way of contact.
Gary Lanzer
Old 12-20-2011, 08:58 AM   #3
j.d.roost's Avatar
Ok,will do. I assume its ok for the stator wire plate to have metal to metal contact?
F1
Roche usa
R.I.P. Jon Williams
Old 12-20-2011, 09:10 AM   #4
The collector ring is common connection between all the terminals so it should not be a problem. Just make sure your can screws are't really long and are hitting the ring when you tighten them down. It will just not allow you to tighten all the way down to tighten motor to you're motor mount.
You should still contact Charlie at NOVAK though.
Gary Lanzer
Old 12-20-2011, 09:42 AM   #5
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I have sent two emails to Novak but have not gotten a reply yet. Wanted to see if anyone else had this problem and if there was anything I could try before I call them later today.
If you need to send the stator back for any reason, or want a response to your tech questions, you'd be better served by calling Novak when addressing this issue. As I've discovered, email has a way of "getting lost in the shuffle", whereas giving them a call will yield far better results.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 12-20-2011, 10:20 AM   #6
Company Representative
I'm sorry that your emails have not been answered; I always suggest contacting Charlie directly for assistance:
[email protected]
NovakTwo is offline   Reply With Quote
Novak Kinetic Cammer Electric On-Road 2043 11-25-2013 05:30 PM
Novak Motor Issue DirtRacer68 Electric Off-Road 22 06-26-2012 08:33 AM
Fixing a Novak motor Neu_Racer Electric Off-Road 9 03-04-2011 11:50 AM
Novak Havoc ESC Caught Fire - Help! secoweco Electric Off-Road 79 12-13-2010 03:42 PM
