TKR TKX-10
Old 01-29-2012, 09:48 PM
  #46
CypressMidWest's Avatar
Originally Posted by CarbonJoe View Post
Since he is a veteran of multiple Sydor Slams, I'd say that is a negative. Trying to avoid being seen, he entered via the back door.
Alignment is critical when using that thing. One slip and you're in deep doo doo.
Probably the same reason he abandoned his AC/DC charger line..... He's done switching back and forth I guess.
CypressMidWest is offline
Old 01-30-2012, 05:28 AM
  #47
Chaz955i's Avatar
Isn't that the expensive way to do it? What about just investing in some new T.I.T.S.? They are available as spare parts, right?
Don't they also make some aftermarket support as well? Some sort of wire that goes underneath? You can also swap to a different weight silicone oil, from what Tommy told me.
The T.I.T.S. can be rebuilt but then there is the grill area that seems to show the most wear.
Chaz955i is offline
Old 01-30-2012, 08:29 AM
  #48
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Yeah, I heard that as well. It really stinks when the A.S.S. gets loose, as it's a real PITA.
Hopefully just a quick use of the pointer finger on this part should give an indication of it's condition. A certain amount of tightness, or friction between the moving parts would be crucial.
nf_ekt is offline
Old 01-30-2012, 07:29 PM
  #49
Chaz955i's Avatar
Actually a three finger approach, two above and one below seems to work best. It's a shocker how easy this car is to set up.
Chaz955i is offline
Old 05-08-2012, 07:55 PM
  #50
Chaz955i's Avatar
Hey everyone, after many delays we are close to offering pre-orders on the TKX-10. Best part is we will throw in the T.I.T.S upgrade for free. You can contact [email protected] for more information.
TKR Racing...Best in China!!!!
Chaz955i is offline
