Droop measurement
how 2 actually measure droop?
by using droop gauge i guess.........
Bad thread title lol.
dakrat is correct.
You can also measure droop on the front or rear by lifting the car in the middle of either end and measure how many mm's the chassis can lift up before the wheel leaves ground. This way you can also see if your car is tweaked or not.
dakrat is correct.
But is there any specific detail on how i can do it?
THe point from which to measure the droop with the droop gauge depends on your what car you're driving.
but here is a good example:
http://www.teamlosi.com/xxxs_page/xxxs_droop.htm
