Old 05-03-2005, 10:45 PM   #121
tc3 racer sc's Avatar
Originally posted by tony rivas
pic 2
hey tony i see u got the shu car agin where u put the hpi car it ur boy reggie from sc remeber me at the hpi race
tc3 racer sc is offline   Reply With Quote
Old 05-04-2005, 12:38 AM   #122
SpeedTech's Avatar
I checked the RI MKII we have in stock and they too have the new style wing. The ridges are more for strength and also streamlining the air flow a bit, but more for strength than anything else
I'll check on the few MKIII we have left tomorrow to see if they too have the new and improved wing
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 05-04-2005, 06:34 AM   #123
ttso's Avatar
Steve Wang
Than I believe SpeedTech got newer batch of MKII. The old MKII (like the one I can find in LHS) is with 175mm wing with no strength rib.
Btw, according to JP RC magazine's article, you will need to have different setup with 190mm wing since it will change the driving characteristic. With the same setup it will only get the car slower.
I believe which means you can freeup the rear mechanic grip by using smaller toe-in, smaller camber, higher roll-center, harder spring. With bigger wing you should able to get the same traction at high speed, but at low speed the rear will be freeup, resulting better low speed steering.
I haven't try my GW3.1 wing yet, probably on Sunday. I wish it works as I predict.
ttso is offline   Reply With Quote
Old 05-04-2005, 04:05 PM   #124
s2
s2's Avatar
hi
has anyone got any clear pictures comparing the RiDE MKI and MKII?
also what are the handeling characteristics of these shells?
thanks for your help
Stew
s2 is offline   Reply With Quote
Old 05-04-2005, 05:56 PM   #125
TryHard's Avatar
Ok, I'm going to break my Ride abstentation (sp?)....
I'm gonna order one of the stratus with an order from speedtech, now at the moment over here in the uk only the Mk1 and 2 are BRCA legal for stock (by being commercially avaliable in the shops). means the 3 and accord are out of the equation.
Which one of these is better suited to the largeish tracks we have over here?
Also I'll be running 27t stock.
As an example, my local track
Ashby
if it helps, tend to gear in the 5.5-5.6 fdr range for here.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 05-04-2005, 06:10 PM   #126
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Ashby
Regards
Ed
Stick with the MKII ..... .that body Rocks ...... and with the infeild thats like that the MKI would leave you wanting a bit more turn in
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽĩ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-04-2005, 06:24 PM   #127
TryHard's Avatar
cheers dave, I was leaning towards the 2 anyway... but that somes it up for me
Now all I need is the DJ.. sorry pro-module suspension to turn up on the speedtech site... and i can order it. Already working on a paint scheme...
Old 05-04-2005, 07:35 PM   #128
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
You can get those bodies and Flap wing here also:
http://www.precisionrc.com/
I use both Accord and Stratus MK2 and there simply awesome.
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 06-01-2005, 09:28 AM   #129
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
been running the accord body for sometime now and i now have a mk3 body. i am wondering whats the difference between the accord and the mk3?
S-T-R-l-K-E-R is offline   Reply With Quote
Old 06-01-2005, 10:26 AM   #130
scoobydo's Avatar
The MK have different downforces from Low (1) to high (3).
The Accord has more of an "All Around" Body with middle of the road downforce. Many have compared it to the Mazda 6. I actually prefer it over the Mazda.
scoobydo is offline   Reply With Quote
Old 06-24-2005, 02:15 AM   #131
V12
V12's Avatar
So that means a MK III would be the best choice for lowgrip conditions? Better then the Accord? I just used a MK II now but itīs the version with the old wing. Iīm using a Flap highdownforce wing now but I still need more rear grip sometimes. What would be the best choice for a better wing? The new version Ride wing or is the Gokuraku 3.1 still the best? Whatīs about the Flap RW? Sometimes we have very low grip conditions and rear traction is the problem there.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 06-27-2005, 03:14 AM   #132
V12
V12's Avatar
Anyone tried the new Ride wing and the Gokuraku 3.1 in compare?
Old 06-27-2005, 03:29 AM   #133
The new ride 190mm wing(actually 185mm) is very similar in performance to the Yok 3.1 straight wing.. . . the newer wings give the MKII/III & Accord a really planted feel.. a little bit more confidence building than the Original 175mm wing..
-Dave
Old 06-27-2005, 09:13 AM   #134
V12
V12's Avatar
Thanks Dave.
That means I donīt need the GW 3.1 as the new Ride wing is very similar.
Just got an Accord and a MK III with the new wing yesterday.
Next race is a very low grip track. We will see which one of the bodies will work the best there.
Old 06-29-2005, 01:18 AM   #135
Thanks Dave.
I think the Accord might be your best bet
-Dave
Ride TC Bodies Ranamar Electric On-Road 7 04-12-2006 10:43 AM
Ride Touring Bodies site link Ranamar Chat Lounge 1 04-12-2006 08:26 AM
ride bodies Slingblade Electric On-Road 13 09-06-2005 06:11 PM
Ride tc bodies on carpet. tc1 Electric On-Road 8 03-02-2005 05:45 AM
Ride Stratus bodies V12 Electric On-Road 13 06-02-2004 11:38 AM
