Old 02-02-2006, 09:57 AM   #181
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
the rayspeed accord is pratically identical to the ride stratus mk.3
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 02-02-2006, 10:01 AM   #182
Frank McKinney's Avatar
Cheers for that!
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 02-02-2006, 10:06 AM   #183
Rayspeed Honda is a bit less agressive than Ride Honda, good for high bit track with one-way.
caveman is offline   Reply With Quote
Old 02-19-2006, 10:50 AM   #184
MrUnlimited's Avatar
Hi guys,
I was wondering what the different between the Ride Accord type B (RI-196) and the standard Accord (RI-195) is. Is ti the wiright or did they redesigned it to give more downforce on i.e. the nose of the car? What wing suits best for large tracks: Flap or Yokomo?
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 02-19-2006, 11:21 AM   #185
Ali Graham's Avatar
The ride type-B is for more flowing, larger tracks, so it has a more stable body design that generates more downforce. In standard levels of grip the yokomo wing is the best bet, however in very high grip the Flap will be better(hara used it at the 2005 TITC)
HTH
Old 02-19-2006, 03:21 PM   #186
V12
V12's Avatar
Really? I think higher downforce means higher drag. You donīt want this on a larger track.
Regarding the Flap wing youīre right. But Hara usually runs a Xenon wing, not the Yokomo wing like others. Moore does the same.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 02-19-2006, 08:31 PM   #187
That's true the higher the downforce the more drag, the lower the topspeed. So what is the difference between the bodies?
Old 02-20-2006, 12:43 AM   #188
dstyles's Avatar
the rear deck has a space in between the wing posts notched out and the molded-in rear deck wing is more prominent. the front lower lip sticks out more like a mazda 6.
dstyles is offline   Reply With Quote
Old 02-20-2006, 01:18 AM   #189
So it is almost the same as my current Excel Accord body. See the attached picture.
Old 02-20-2006, 02:09 AM   #190
Ali Graham's Avatar
True, higher downforce higher drag. BUT if you remove the downforce or stablness, you get a more "unsettled" handling charicteristic with more turn-in, more suited to small, tight tracks. The type-B probably doesn't generate more downforce then, it might just have had a slight remodelling for the roof and bonnet to make it less aggressive. the difference in handling is noticeable.
In fact neither Hara, Surikarn or Moore were using xenons or gw31 wings at the TITC, they both appear to have run what I think is the Yokomo curved wing, judging by the one in front of me. It is very sloped, curved as the name suggests and has a small, squarish lump, providing less downforce than the gw31 straight. Can be seen in this pic:http://apartmentinbkk.com/photos/?al...l&img=P1020387
http://www.hotbodiesonline.net/05_ii...s/DSC00362.JPG
This pic shows all 3 HB cars at the IIC, 'Karn and Andy with xenon type-As, Hara with a gw31. Has anyone found any handling differences between these 2?
Old 02-20-2006, 03:13 PM   #191
Send a message via AIM to BONZAIII Send a message via Yahoo to BONZAIII
Hey guys I am looking for a body other than Protoform's Mazda6.I am going to race this car on asphault with low to medium traction.My car is an FK05 and the class will be 19t on rubber tires.The track dimensions are 160x60 .It is somewhat of a flowing with technical sections in it.Which body and wing selection should I use?And where can I purchase these items?Thank you Rodney.
BONZAIII is offline   Reply With Quote
Old 02-20-2006, 03:36 PM   #192
V12
V12's Avatar
Yes really looks like the Yokomo curved wing at the first picture.
Until now never tried anything other than the GW3.1 straight wing. Just got a Xenon but yet have to try.
Old 02-20-2006, 08:34 PM   #193
FBJ's RDX's Avatar
Yes, they are Yokomo Wings. The wing used by hara seems to be a Yok wing too. The xenon wing is kinda different, they have a larger hump.
FBJ's RDX is offline   Reply With Quote
Old 02-20-2006, 10:20 PM   #194
i would recommend excel stratus type 1 or excel accord type 1
for more aggresive steering go excel accord type II
if you would like more rear downforce use excel stratus type II.
flysti is offline   Reply With Quote
Old 02-20-2006, 10:29 PM   #195
dstyles's Avatar
xenon also sells a straight & curved wing. they lack the hump in the middle and can be distinguished by the checkered grid for mounting guidelines.
Ride TC Bodies Ranamar Electric On-Road 7 04-12-2006 10:43 AM
Ride Touring Bodies site link Ranamar Chat Lounge 1 04-12-2006 08:26 AM
ride bodies Slingblade Electric On-Road 13 09-06-2005 06:11 PM
Ride tc bodies on carpet. tc1 Electric On-Road 8 03-02-2005 05:45 AM
Ride Stratus bodies V12 Electric On-Road 13 06-02-2004 11:38 AM
