Old 07-05-2005, 09:35 AM   #166
s2
s2's Avatar
Default Wing Comparisons
Here are some pictures of the Flap Type-R and the Xenon C/D wings.
Flap concave kinda trumpets as it gos back along the wing, where as the Xenons concave height are constant.
Xenons make Type-R look tame
Ride Touring Car Bodies-flap-type-r-front.jpg   Ride Touring Car Bodies-flap-type-r-back.jpg   Ride Touring Car Bodies-flap-type-r-top.jpg   Ride Touring Car Bodies-xenon-c-d-curved-top.jpg   Ride Touring Car Bodies-xenon-c-d-curved-front.jpg
s2 is offline   Reply With Quote
Old 07-05-2005, 09:37 AM   #167
s2
s2's Avatar
Default Wing Comparison continued
more pics
Ride Touring Car Bodies-xenon-c-d-straight-front.jpg   Ride Touring Car Bodies-xenon-c-d-straight-top.jpg
Old 07-05-2005, 11:52 AM   #168
TryHard's Avatar
Originally Posted by V12
Hmm... interesting. Tried the MK2 with the Flap highdownforce wing on a small track and had some oversteer on cornerexit, more than I liked. But have no Flap RW. Itīs also one of the wings I thought of but there are too much wings in Japan available and I didnīt wanted another curved one.
Ed, which of the Ride wings did you compared the RW to, the old or the new one?
The new version that came with the stratus. The one with 4 or 5 ribs in it.
just a pointer, the R is, I think, 175mm wide, the RW is 190mm wide, but has a less extreme centre section than the R.
HiH
| THard.co.uk | Xray | MuchMore |
Old 07-05-2005, 12:40 PM   #169
V12
V12's Avatar
HiH
That means the RW is better than the new Ride. And what did you think of the R?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 12-28-2005, 03:17 AM   #170
Send a message via ICQ to MattW
So, where did anyone end up with thought on what was the best wings to use??
Has anyone tried the Excel flat wings (EA031) anyone know if they are 175 or 190 width.
MattW is offline   Reply With Quote
Old 12-28-2005, 04:54 AM   #171
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
I;ve been trying the mk3 on a tigh twisty indoor track, the std wing was awful, with the gw31 straight the car pushed on entry, but then rotated mid-corner, felt alright but a bit hard to judge. Tried the curved wing that comes with the gw31 straight and car rotated a lot more, felt less sluggish and was much more aggressive, gained .15 a lap and thats on a tiny track with 11 sec laps! I don't think it'd be any good with any of the high-downforce wings.
Haha stew your like the tech master on this thread, I should have known
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 12-28-2005, 08:35 AM   #172
Charles Godwin's Avatar
Just ordered a Ride Honda Accord (A) and i was wondering what the shell handles like compared to a PF Mazda 6 or a PF Dodge 1
Thanks, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-28-2005, 09:01 AM   #173
dstyles's Avatar
I've found that the RI-195 TSX to work well on medium - high traction asphalt with either the FLAP Type-RW wing or the Yokomo 3.1 wing set.
dstyles is offline   Reply With Quote
Old 01-03-2006, 08:56 AM   #174
Rob Phillips's Avatar
What did you think of the Xenon wings with the Vers 1 TSX? I just ordered one, I guess I will be trying it out soon for myself.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 01-03-2006, 11:18 AM   #175
Charles: I think when comparing Ride accord to PF Mazda 6 you will find that the Ride has less turn in steering but more mid corner steering and a lot more corner exit steering than the mazda. I really like the feeling of the RI, easier to drive compared to the mazda.
moonman is offline   Reply With Quote
Old 01-03-2006, 12:26 PM   #176
Thanks moonman, just got my Honda Accord from Speedtechrc. Looks really cool . Also i've just ordered a yokomo 3.1 wing set so i'll hopefully try that as well
Charles
Old 01-03-2006, 01:21 PM   #177
Ali Graham's Avatar
the yokomo 3.1 set is dialled. I did some (a lot ) of testing at my track with wings on different shells, biggest affected by different wings was the stratus mk3. With the GW3.1 straight, not much quick response on turn in, but it also failed to rotate properly mid corner. With the curved wing that comes in the yok wing set it rotated more, which led me to think the least amount of downforce would be better. I then tried a mates flap RW, same curve as the yok but with the rather large hump in the middle. The shell was absolutely dialled then, turned in sharp but smoothly and rotated very well without being unstable. After testing on various shells, my thoughts are that the GW31 straight wing seems to make the shell push on entry a bit more, but exits the same as most others. Anybody else got any testing results/theories?
Old 01-03-2006, 02:48 PM   #178
berger's Avatar
R/C Tech Charter Subscriber
As well as changing the shell, try moving the height of it also, a hole front or rear can make a subtle difference to how it handles
berger is offline   Reply With Quote
Old 01-03-2006, 04:23 PM   #179
MrUnlimited's Avatar
I have a Excel version of the Accord body.It vis an exact copy of the Ride Accord It's very lightweigt but if you hit a wall it easily deformes which results in bad handling. Next body will be a Ride version which is stronger I hope.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 02-02-2006, 09:27 AM   #180
Frank McKinney's Avatar
Just picked up a Rayspeed Accord, does anyone have any opinions on it, like what Ride bodies it's similar to, etc.? The cabin looks pretty far forward, with plenty of trunklid space, plus it has the raised-in-the-middle wing. The front lip/splitter is pretty hefty but it doesn't have winglets on it. I think mine is the RS-26 model
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Ride TC Bodies Ranamar Electric On-Road 7 04-12-2006 10:43 AM
Ride Touring Bodies site link Ranamar Chat Lounge 1 04-12-2006 08:26 AM
ride bodies Slingblade Electric On-Road 13 09-06-2005 06:11 PM
Ride tc bodies on carpet. tc1 Electric On-Road 8 03-02-2005 05:45 AM
Ride Stratus bodies V12 Electric On-Road 13 06-02-2004 11:38 AM
